XR650L pilot jet question
3 replies to this topic
  • txmedic
Posted June 26, 2007 - 11:00 AM
Several searches have yielded different answers. Is the pilot jet that comes stock a different series than what is used to replace it? The OEM pilot appears to be a 26 series and the recommended replacement is a longer 21 series. Does that sound correct?
The OEM shorter pilot is recessed into the carb while the 21 series appears to be flush.
Also someone gave a part number for a hex style main. I bought the 8mm round to replace the the same style OEM main jet. Which is correct?
  • martinfan30
Posted June 26, 2007 - 12:17 PM
i ran into that too. didnt switch em tho cause i bought a fcr.
  • XR650L_Dave
Posted June 26, 2007 - 12:32 PM
The longer one is incorrect, but will work.
I'm not sure, but I think the longer one I'm using might make it a little richer than the 'proper' one.
If you use the longer one, you may need to trim the slosh baffle to keep it from covering the pilot jet hole.
Dave
  • Denn10
Posted June 26, 2007 - 01:17 PM
i found those mains in the little podunk shop also LOL got a 162 and 165 for testing but im sure the pilot is the 21 series but i had alot of those so didnt have to buy any
  • 17 replies
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
  • 22 replies
