Crash in Rear Rim
5 replies to this topic
  • beerjonny
Posted June 26, 2007 - 06:40 AM
** Title should read 'crack', not 'crash' (can't figure out how to edit it) ***
Got a couple flats this week, unusual as I run HD tubes and have gone quite a while without one.
I run a 2004 XR650R stock rims.
Still not sure this is the cause, but I found it while pumping up my last tire.
Anyways, can I just get this welded and then grind the weld down a bit???
  • dezracerE
Posted June 26, 2007 - 07:14 AM
It happens.
Probably more often here in the desert south west with high speeds and rock impacts.
It will get worse. I would replace with an Excel. About $150-175 with spokes.
Not too hard to do.
You may want to drill a small hole at the end of the crack to stop it from spreading and clean it up so you can keep riding until ready to replace.
  • beerjonny
Posted June 26, 2007 - 07:33 AM
It happens.
Not too hard to do.
Thanks for the reply. I was hoping to avoid the excel route, but may go there for peace of mind.
I am doing a 4500km trip in a month, so i want it to be 100% for it, but for the same reason, cash flow is tight.
I like the idea of drilling a stress releif hole. I may try and drill a small hole, get a good welder to run a bead over it and grind it if I need to.
If it looks bad after the work is done, I'll have to step up to an aftermarket rim.
Thanks.
  • Phuzzy McPhuzzface
Posted June 26, 2007 - 09:05 AM
Is it cracked on the inside wall, too?
The rim's edge should be rolled over to create a double-wall structure. I would think that by drilling a small hole at the tip of the crack and welding (heliarc?) it, grinding it down some, that would be a strong repair, especially if the inner wall was undamaged.
I'm no metallurgist, however. Just a gut feel.
  • beerjonny
Posted June 26, 2007 - 11:05 AM
We have a top notch AL welder in town... I will take the rim into him and get some thoughts.
Thanks guys
  • hawncase
Posted July 11, 2007 - 12:09 AM
So what happened? Were y0u able to weld it?
  • 4 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
