How to improve turning/steering on '07 WR450?
16 replies to this topic
  • xrmarty
Posted June 25, 2007 - 08:24 AM
I love my bike in the desert, but when I ride it in tight technical terrain I hate the turning on this bike. It's like it wants to go straight; not very responsive.
What are my options? I'm planning on doing the following: drop fork tubes and raise rear preload. I would like to change off-set on the triples but I can't seem to find anyone that makes clamps for the WR (YZ no problem:mad: ) with different off-set.
Rekluse E-axle looked like a good solution but, again, they only make it for the YZ
Any input would be greatly appreciated
Marty
  • WGP
Posted June 25, 2007 - 09:20 AM
Raise forks in triple clamp=lower's front end and turns quicker.
Drop forks in triple clamp=front end is higher and more stable at high speeds
You can also change things with the rear wheel.....
Longer chain= longer overall length and increases high speed stability
Shorter chain= shorter overall length and will turn better.
If you ride both woods and desert you will have to find a happy medium.
1st step is always correct sag too.
  • Mutu
Posted June 25, 2007 - 09:25 AM
Re-spring / Revalve. The best way to spend money on your bike.
Do this first before spending money on triples or e-axle.....
  • xrmarty
Posted June 25, 2007 - 09:44 AM
That's what I meant. I just got it mixed up:bonk:
I like the idea with the shorter chain.
Already did that. You're right, best money ever spent. Like I said, the bike is great in the desert. Great handling, takes whoops like there is no tomorrow. I just don't care for the steering geometry in tight technical stuff.
When I had my suspension done, I believe the forks were already raised as much as possible. If I increase pre-load on the rear shock, I'll have to get a lowered seat for sure.
  • GCannon
Posted June 25, 2007 - 11:08 AM
Better front tire??? Then adjust air pressure to suit your needs.
  • xrmarty
Posted June 25, 2007 - 08:29 PM
I'm switching to Dunlop 756
  • fitzy
Posted June 26, 2007 - 05:00 AM
90-95mm sag is what you want, as per the book. not the normal 100-105
Drop the forks down to about2-3mm below the first line on the forks.
This fixed mine and still no real headshake. Turns well now:thumbsup:
  • ffgman
Posted June 26, 2007 - 12:46 PM
When I ride in the tight stuff I also run about 90mm sag and it turnes great. I think if you do that you be suprised.
  • xrmarty
Posted June 26, 2007 - 03:46 PM
I'm definitely gonna try that this weekend. Now, I just have to figure out how to lower my seat, as I'm barely touching the ground now.
  • Derwud
Posted June 26, 2007 - 06:29 PM
This is what happens when your WR won't turn..
  • xrmarty
Posted June 26, 2007 - 08:30 PM
Dang! That looks like it hurt. Hope you recover soon. Are you serious about what you said about the wr not turning? what happened?
  • SXP
Posted June 26, 2007 - 08:34 PM
Tibial Plateau Fracture? (See my avatar on the left).
  • Bamster
Posted June 27, 2007 - 03:33 AM
Are you sitting or standing through the technical stuff?
  • Derwud
Posted June 27, 2007 - 07:12 AM
Wow, that looks just like my X-ray....
  • xrmarty
Posted June 27, 2007 - 07:55 AM
I try to stand as much as possible. When I'm just inching my way across in some nasty rocky stuff then I'm probably sitting.
  • VB_Racing
Posted June 27, 2007 - 08:43 AM
Honestly, that is when you should be on the pegs as much as possible. A tip that I use is to apply the rear brake and clutch to help you with balance.
I have found that the WR handles alot better, and feels much more agile(flickable) when you are standing in technical situations. I live in WI and ride some pretty technical woods stuff.
Dave
  • Vegemite_luva
Posted June 27, 2007 - 10:38 AM
I find on my 03 with BRP clamps my bike turns easier when I lean back. Not sure why but I agree you should stand as much as possible in tight technical terrain. I also find leaning with the bike making sure your hips and shoulders are in the same plane as the bike helps too.
