A quick blip of the thottle and the engine dies
9 replies to this topic
  • Skip
Posted September 10, 2000 - 02:56 PM
Hope you guys can help. I have a stock '00 WR400, I just broke in the engine, I also just cut down the rev limiter screw to the recommended height (some peole say 8.5mm others say 9mm, I cut it down to 9mm to play it safe)
Now when I give a quick blip of the the thottle to about 1/4 open the engine dies. The rev limiter doesn't have any thing to do with this,right? I checked the needle seat to see if there was any grit in it, there wasn't, should I raise the needle up or down? It has the the stock jets in it.
The bike is extremely clean too, as in the airfilter/airbox
  • Clark_Mason
Posted September 10, 2000 - 07:28 PM
There are lots of jetting stuff on the site just search but I will offer the following to get you started.
Put in a 48 pilot jet
Run the fuel screw at 1.5 turns out
use a minimum of a 175 main jet
Run the stock DRS needle in the #4 or #5
You really should ditch the stock DRS needle and run a DVP in the #5 or #4 slot.
Should be good for sea level to 4000 ft of altitude.
Happy Trails
Clark
  • Taffy
Posted September 11, 2000 - 01:16 AM
make sur ethat when you open the throttle your accelerator pump jet is squirting fuel. Taffy
  • Guest_Guest_*
Posted September 11, 2000 - 03:05 AM
mine was doing the same thing I had to clean my excelerator pump... or how ever you spell it .... the rod that goes into the pump gets dust and dirt in it so try that
  • cphillis
Posted September 11, 2000 - 08:00 PM
I have the same thing with my WR and I have tried to cure it, there is no cure, the four stroke will always have this hesitation it is not like a two stroke. You can try richen up the pilot jet but that is about it. When you ride the bike the hesitation is gone because the higher rpm's. but from a idle and you wick the throttle it will hesitate or die. Just once in a while I can get a hesitation on accel when I am riding on a track but that is it. If you do find a cure post it for me.
  • Skip
Posted September 12, 2000 - 07:31 PM
I think I fixed it. I dropped the 'e' clip down one slot (#4) richened it up a bit it seems to work with the stock jets. It seems to be running fine. The neighbors hate me though from 'testing' all weekend. Oh one more thing. I know on mine the rev limiter was cut wrong,am I the only one? (the dealer said 8.5mm from the bottom of the head) the end of the bolt comes no where near the stop.To keep from over reving it. I got a new bolt (12mm) from the bottom of the head. This (at least on mine) works. I've read that everyone is using pliers to remove this limiter it's a 5mm allen bolt on mine. I just used an allen key it came right out. Maybe 5 min at the most. Keihin slide carb. The picture on the web page I looked at looks like a different carb than mine ('00) Sorry I'm new to this bike, like most of us. Thanks for this kick ass page guys/(girls?) I'm so used to 2 strokes, taking a bit to get used to. I DO like NOT fowling plugs all of the time!
  • Skip
Posted September 12, 2000 - 11:42 PM
Oh yeah almost forgot...I turned the fuel screw out 1.5 turns.
  • Guest_Guest_*
Posted September 13, 2000 - 05:01 AM
Skip why mess with cutting the throttle stop? Just buy the one for the 426 and install it! :)
  • Skip
Posted September 13, 2000 - 07:55 PM
Well it's done now!!! Thanks anyway
  • Kermit
Posted September 17, 2000 - 11:19 AM
Just let you know It's working great now. I listed below what I did. Of coarse I'll have too play with it again when I switch the timing to YZ and a better pipe.
