bog
6 replies to this topic
  • rmandyzf
Posted 23 June 2007 - 04:27 PM
my brother was out riding my 07 yz250f and after about ten minutes the bike bogged and shut off. It started back up first kick but it wouldn't idle so I adjusted it but it still really doesn't want to idle.Also I just had the carb out for cleaning so I'm thinkin maybe I have a clogged pilot jet or something. So I just filled the bowl with carb cleaner and I'm gonna let it sit overnight. wat do you think?
  • Trick188
Posted 23 June 2007 - 04:49 PM
letting your carb sit several hours with carb cleaner in it will hurt more than it helps, that stuff is very hard on plastic (floats) and rubber (valve tip) Take the carb off again and clean it and drain your fuel tank and replace with fresh fuel. Also check your vent line to the tank.
  • mxmatt15
Posted 23 June 2007 - 07:13 PM
check the jetting and fuel screw
  • Trick188
Posted 23 June 2007 - 07:17 PM
jetting wont make your bike bog and just shut off after 10 minutes....
  • glock35
Posted 24 June 2007 - 06:40 PM
I am having the same problem on my 06 kxf250. Any ideas?
  • YdogsflY
Posted 24 June 2007 - 06:43 PM
run a search on "bog", tons of info. and check out this link. welcome to TT.:thumbsup:
http://www.thumperta...ad.php?t=239791
  • armstrong789
Posted 24 June 2007 - 06:44 PM
well he was probably riding it like a pansy and never goosed it hard enough:prof:
