Clark Gas tank issues
8 replies to this topic
  • yam314
Posted June 23, 2007 - 12:07 PM
I have a large Clarke tank on my 07 YZF. The stock petcock is facing the wrong direction and forces the gas line to make a big 180 deg loop that could catch on a branch. There is not enough room to flip it around as it will hit the cylinder head. Where is a good source for petcocks? It looks like a stock 03-05 petcock will work OK. I suppose I could order one from Yamaha.Has anyone else encountered this problem?
Posted June 23, 2007 - 12:17 PM
Everyone who has a tank like yours has. I dealt with it by using two '03 petcocks that I bought through Thumper Talk OEM Parts for about $30 for the pair. I was thinking of using the '06 petcock on the right side, but it looked like it might hit the head bolt. The setup looks like this:
http://www.thumperta...918#post4069918
  • 2012 450 xc-w
Posted June 25, 2007 - 06:31 AM
Use a petcock off a WR. It will work and give you a reserve as well.
  • jjgixxer
Posted June 25, 2007 - 07:29 AM
Agreed, I bought a 06 wr petcock. I believe the 07's wr petcocks are different.
  • yam314
Posted June 25, 2007 - 01:46 PM
That is just what I am looking for. Nice looking bike. What kind of pipe is that?
Does anyone know if the 2001 WR petcock will fit as it is the only one listed thru Thumpertalk?
  • jjgixxer
Posted June 25, 2007 - 02:06 PM
Thanks, it's a whitebros alum pro . :thumbsup:
I'm not sure on the 2001, I don't see why it wouldn't. I would have to take a look at the diagram.
Posted June 25, 2007 - 02:52 PM
It should. The o-ring gasket that seals it to the tank is the same PN.
  • desertyeticheyenne
Posted June 26, 2007 - 10:15 AM
One more tip for you guys regarding fuel line routing , wrap the fuel line with fire sleeve. I will try to get a pic. up soon, the fire sleeve is rated at somewhere around 2500 degrees fairenheit and can handle direct contact with exhaust, will eliminate fire danger in the event of contact. Scary situation as I have dealt with this issue on a poorly prepped bike that showed up for a day ride in Ocottillo Wells. Fire sleeve can be purchased at Crown Performance phone # 760-599-0090. I have used this on many race car /pre-runner applications and will attest to it's durability, heat resistance.
Correct name is Crown Industrial Products Inc. Talk to Fermin he is very helpful/ knowledgeable.
T.Lee
  • black_n_blue_thumper
Posted June 28, 2007 - 10:13 PM
:thumbsup: :thumbsup: :busted:
Thats what I did too. Works awesome. Then I leave it on that tank, makes switching tanks a breeze.
  • Hot  113 replies
  • Hot  38 replies
  • 0 replies
  • Hot  30 replies
