-April 22, buy brand new 06 WR450.
-Do all free mods (AIS, debaffle, snorkle removal, airbox cutouts, YS throttle stop, grey wire)
-JD Jetting kit
-200 miles, couple 1'-2' deep water holes were ridden through, with 3 oil/filter changes, nothing suspicious, life is good
-Get suspension revalved, install myself.
-60 more miles water-free miles, life is better
-Oil change, notice milky oil, scratch head, put in new filter and yamalube.
-Run 5 miles, notice slight differences in engine sounds, but still running strong as ever.
-Run 5 more miles, hit one 1' deep creek
-Idling around in parking lot and all of the sudden SEIZE
-Starter just clicks, kick-starter stuck, roll start = no luck.
-crack frame plug, oil comes out
-open oil fill plug, lay almost on ground, oil comes out, looks clean.
So, I took it to the stealership to see if it will be covered under warranty. Won't know what they say until next week.
After searching around a little bit, my best guess is water pump seal? I ran through some water, but never submerged it and only went through at about 5 mph.
If it is the water pump seal, I guess it would be covered under warranty
