Stock baffle/Vortip problems
5 replies to this topic
  • Mark_B
Posted February 18, 2002 - 06:05 AM
I need some help, I have broken three stock baffles and yesterday a Vortip insert. Do I have a problem with jetting or somthing else? The bike is stock, the jetting is stock, the airbox has not been altered, the timing is WR standard, and I have not done any of the mods suggested on this board. I ride at elevations of 2000' to 4000'.
Any help or ideas would be appreciated. Thanks.
  • tbronco
Posted February 18, 2002 - 02:11 PM
How, in what way?
  • Mark_B
Posted February 18, 2002 - 04:13 PM
They break where the bolt mounts it to the muffler. It is not the result of crashes so I am kind of at a loss and wondering if it is jetting related. I have run the bike without the baffle but I do not notice any backfire. If any body could enlighten me I would appreciate it.
  • tbronco
Posted February 18, 2002 - 04:35 PM
is your bolt too long? It should be somewhere around 3/8" long. Might be bottoming out against the inner pipe???
I would think that if it were broken by backfire you would know it without a doubt.
  • Mark_B
Posted February 20, 2002 - 12:08 PM
Opinions anyone?
  • tp3dxf
Posted February 20, 2002 - 08:53 PM
I have the same bike and ride in the same elevation. I have never had a problem like yours. I think you may have your bolts too tight? Heat expands metal? I mean bolts don't just brake for no reason. If they are bottomed any flex may rip up a bolt. How are they broken? Are they really broke or torn. You see there are different ways that a piece of metal is broken can you expand.
