front fork oil level
2 replies to this topic
  • marty_mosley
Posted February 09, 2000 - 07:24 PM
Has anyone changed oil level in thier front fork ? currently set at 125mm (stock)and want to know if more oil = stiffer ride. Thanks for any help
  • Kevin_Lysdahl
Posted February 09, 2000 - 07:48 PM
  • Kevin_Lysdahl
Posted February 09, 2000 - 07:54 PM
If you are bottoming, a higher oil level will reduce/eliminate your bottoming. How are your forks in the initial stroke (plush, stiff)? An option is too go to a heavier oil, or a heavier spring.
What is your weight, what is your level (novice, intermediate, expert), what type of terrain do you ride and at what speeds?
