Big gun SDS Velocity header and Silencer
10 replies to this topic
  • William
Posted February 14, 2000 - 12:46 PM
Has anybody purchased this product, please tell me what you think.
Also what do guys think is the best mod. for low end and mid range that is still not to loud thanks
2000 WR400F
  • brurag
Posted February 14, 2000 - 03:54 PM
I also have a 2000 WR400F and installed the the "FMF Powercore IV Muffler" and "Standard FMF Head-pipe". Iv'e only had a chance to ride the bike once and my opinion is that it's not too loud. Again, that's my opinion. My friend has a 98 WR400F and he took the bike for a short rip. He definitely noticed an increase in power through the whole range. This bike has explosive low to mid grunt.
Dan in Washington
2000 WR400F
  • William
Posted February 14, 2000 - 07:01 PM
Dan, Was that the Hi-Flo header from FMF?
  • brurag
Posted February 14, 2000 - 08:16 PM
Yes, the "Standard" Hi-Flo Head-pipe. They make two sizes (Standard and Desert). The standard pipe, which is almsot the same diameter as the stock pipe, gives you more low to mid-range power and the dessert pipe, which is larger in diameter, gives more top-end power. Therefore, I would recommend the standard for what your trying to achieve.
Dan in Washington
2000 WR400F
  • Clark_Mason
Posted February 14, 2000 - 08:40 PM
My opinion is the power core IV is tooo loud. The best pipe for quietness and a performance gain is the FMF Mega Max. I just happen to have one for sale. It will not fit under my new carbon fiber side panels. These side panels fit tighter than stock so I must run my loud e-series.
Anyway I have the complete FMF Mega Max and the FMF ceramic coated standatd performance header for sale for $190.
Clark
  • Gordon
Posted February 15, 2000 - 05:28 AM
Clark will that pipe out perform a stock yz pipe? Also does it have a spark arester, I assume it does. What is retail for that combo? What other pipes have you tried?
  • Clark_Mason
Posted February 15, 2000 - 06:39 PM
I have run the Yoshimura racing Ti exhaust system-too loud for me but excellent performer. My friend purchased it from me for his 426. It out performs stock YZ, FMF power core IV and probably everything else except the DSP. Yoshimura makes the Ti pipes for DSP so the performance will be similar. The Yosh was a upper mid range and top end pipe.
WB e-series Carbon fiber pro-meg with the WB titanium tapered head pipe. With more than 7 disks it is loud. I run 12 its loud. This combo gives good bottom excellent bottom to mid range pull but is soft on top. It does not rev out like the Yosh or the FMF. If I used the WB racing header then it would shift power upstairs (ie top end better bottom end worse). The power band on this pipe is very good.
The FMF Mega MAX II with the FMF ceramic coated head pipe is I think and excellent all around performer and the one I like the best of this bunch--but it doesn't fit under my Carbon Fiber side panels. It is quieter than the others even with 12 disks installed and it comes with a quiet core which makes it very quiet at the expense of performance. Excellent low end torque and mid range pull and it does not sign off on top like the WB--probably due to header. This pipe on top revs a little slower than the Yoshimura but is an excellent performaer for trail riding situations. How it compares to a YZ pipe don't know but it is quieter. It would be on my bike now if it fit. As to cost I'v seen the tail section as low as $199 mail order and the header goes for aroung $125 discount. This exhaust system is in excellent condition and comes with the quiet core and head pipe spacer so you can run either the stock header or the FMF header.
Clark
  • Gordon
Posted February 15, 2000 - 07:13 PM
Thanks for the good info. One last question does it have a spark arrester? If so I will take it for my mountain riding.
  • Ben_Young
Posted February 16, 2000 - 08:57 AM
Dan
Was that the PowerCore IV-2
you put on your WR?
  • brurag
Posted February 16, 2000 - 05:41 PM
No, I purchased the PC IV-SA (spark arrestor). The square pipe wasn't available yet. Even if the square pipe was available, I would of purchased the PC IV-SA. I spoke with a few riders in the area that have tried different combos, and they recommended the PC IV-SA with the standard FMF head-pipe. Also, the crisp sound of the pipe is a good thing!!! :)
Dan in Washington
2000 WR400F
  • Clark_Mason
Posted February 16, 2000 - 08:29 PM
Gordon
Yes the FMF Mega Max is a forestry service approved spark arrestor pipe when the disks are installed on the end.
Clark
