00WR 400 JETTING
4 replies to this topic
  • Guest_Guest_*
Posted February 15, 2000 - 06:28 AM
Anyone have jetting specs for 00 wr 400 (california)? My bike has airbox and exhaust restrictions removed, i generally ride in the 2000-6000 Ft. elevation range. The bike seems way lean, especially on the bottom.
  • Ron_in_SoCal
Posted February 15, 2000 - 08:17 AM
I also experienced a lean condition when I removed the exhaust restriction and airbox snorkel. By simply raising the needle by only one grove, the bike ran perfectly up to about 6,000 feet.
I have since performed the YZ timing mod and installed a DSP pipe to my '00 WR, and am going through the typical re-jetting ceremony. I think I am close (the recommended 48 pilot / 180 main jets are too rich), and once I get it dialed I will post my settings.
Hope this helps.
  • Gordon
Posted February 15, 2000 - 09:38 AM
How do you like the dsp pipe?
  • Ron_in_SoCal
Posted February 15, 2000 - 09:58 AM
Gordon:
The DSP pipe is awsome. The fit is perfect and it makes power everywhere.
  • Guest_Guest_*
Posted February 15, 2000 - 10:16 PM
i have been doing alot of fidling w my oowr jeting lately. i installed a yz426 pipe & started fouling plugs. using an exhaust gas anylizer. stk 42 pilot, 2 turns, 4th clip. or 45 pilot, 1 turn, 3rd clip. both w stk needle & 170 main. this last seems to work out pretty well.
