03 450 how hot?
15 replies to this topic
  • chastastic
Posted June 20, 2007 - 12:09 PM
how hot should my 450 be running, i know that they run pretty hot, only reason i ask is that the exhaust pipe is melting anything that gets near it ie. one carb vent hose, and the airbox melted straight thru! the engine gets way to hot to touch really quickly
  • Wyatt
Posted June 20, 2007 - 12:53 PM
Check and make sure that your hot start is not stuck open. If so, the bike will run extremely hot.
  • Ga426owner
Posted June 20, 2007 - 01:14 PM
And make sure you do not leave it idling more than a couple minutes at the most:thumbsup:
Welcome to TT:p
  • chastastic
Posted June 20, 2007 - 02:38 PM
how do i know if the hotstart is stuck open, i just roed it for a couple minuts and almost the whole from t half of the pipe was red hot!
  • Ga426owner
Posted June 20, 2007 - 03:30 PM
OMGGGGGGGGGGGG he said it.........:thumbsup: :busted: :cheers:
Get The Bubba burgers and the Brats out it's cookout time again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :thumbsup:
Chastastic....you are now officially registered/broken in at TT.........:bonk: :lol: :lol: :worthy: :worthy: :p
  • 2wheels-drz
if ur hot start opens and springs back closed...its not stuck open. if ur riding it, the pipe should not glow, only when sitting idle. dump question, u checked the coolent and oil?
  • 2wheels-drz
Posted June 20, 2007 - 03:32 PM
no onions on mine, and where the hell is the cheese?? what the hell kinda BBQ is this?????
:thumbsup: :busted:
  • chastastic
Posted June 20, 2007 - 03:46 PM
yeaaa, i just reconneted the hotstart so i dont think its stuck. i was just curious because i'm new to 4stroke dirtbikes and i guess i'm not used to running this hot. coolent and oil levels are a-ok. waterpump?
  • 2wheels-drz
Posted June 20, 2007 - 04:03 PM
i would dout its the water pump, if the seals are gone u would see a constant drip for the weep hole located at the bottom of the water pump housing. i think an exhast leak could cause it to run hot too..maybe wrong. Make sure there is no foreign debris blocking the shrouds (grass, dirt, etc.)
  • chastastic
Posted June 20, 2007 - 04:21 PM
cool, i guess it's just normal. i was just curious because of the melting plastics?!
  • davidl9999
Posted June 20, 2007 - 04:24 PM
Melting plastic is not normal.
Pull the hot start lever and see if the idle bumps up and goes down when you release it. The hot start hould be ok if that happens.
If you packing is used up, the muffler will get hot and can melt stuff. I'm guessing that's the issue.
  • chastastic
Posted June 20, 2007 - 05:39 PM
yea i removed the muffler and it feels pretty much like an empty pipe? - the bike is pretty loud too/ pops alot when downshifting
  • chastastic
Posted June 21, 2007 - 01:26 PM
also it's not the muffler part of the pipe that is getting hot just the midpipe where it is still thin
  • chastastic
Posted June 21, 2007 - 04:58 PM
also letting it idle for a minute or two should it get hot enough to melt thru the airbox?
  • OUCR250R
Posted June 22, 2007 - 05:11 AM
It sounds to me like your jetting is a touch on the lean side. Try setting your air screw and see if that helps. There is a great write-up on how to do that on here. Also if you don't have a zip-ty fuel screw I highly recommend it.
  • Ga426owner
negative.....
  • On January 15, 2017
  • 0 replies
  • Hot  47 replies
