Installed a FCR41mm on my 06'XR650L with stock airbox
17 replies to this topic
  • 2000dr650
Posted June 20, 2007 - 09:31 AM
HELLO ALL,
I just wanted to share my results of puting a Khein FCR41mm on my 2006 xr650L using the stock air box with a K&N. First, I want to start by saying the stock carb, well, totally sucks. no pun intended :thumbsup:. I tried the dynojet kit with ok results but i couldnt get it just right, daves mod is deffinetly better, but still not as crisp as i think it should be(but it is a CV carb, so maybe its as good as it gets??).
So I installed a 41mm fcr that i had on my previous bike, a 2000 suzuki dr650.
The only real problem came across was that the stock carb thoats on th XL are a little bigger in diameter the the stock DR carb, i think by 3mm but the problem was solved with a couple of hose clamps. Im not sure but I bet sudco has a "KIT" for the XR as thaey did for the DR.
I also removed all the smog crap, installed block off plates, and just connected the crank case breather tube to the air box as it was before, just bypassing the smog pump that is nolonger there.
All i can say is this thing RIPPPPPS.... power is instant, no hesitatrion what so-ever
FCR specs.
PJ:52, MJ:160, SAS:1 turn out, CJ:55, N:JD(jdk001) 3rd clip
http://i16.photobuck...0/venttubes.jpg
http://i16.photobuck...0dr650/fcr1.jpg
http://i16.photobuck...dr650/close.jpg
  • martinfan30
Posted June 20, 2007 - 10:52 AM
i have the same carb on my 650L. LOVE it!! i agree totally this one rips too! only thing i got buggin me is the mixture screw. it only seems to have 1/4 turn from left to right. am i just that 'tarded and trying to adjust the wrong thing???:thumbsup:
  • 2000dr650
Posted June 20, 2007 - 11:00 AM
you should have 3.5 turns out from "lightly seated" of the mixture screw..i'd say remove it, completly clean the threads and re-install.
  • martinfan30
Posted June 20, 2007 - 11:51 AM
is it the one on the bottom of the bowl?? cause i dont see any other.
  • 2000dr650
Posted June 20, 2007 - 12:33 PM
yup..i..you could replace it with a xtended fuel screw off ebay..makes tuning a whole lot easier
  • XR650L_Dave
Posted June 20, 2007 - 01:07 PM
I'll be the 1st to say the CV carb will never be as good as a manual-slide carb.
Dave
  • rmhrc630
Posted June 20, 2007 - 01:46 PM
HELLO ALL,
FCR specs.
Hey nice fitup there mate.
I run the 41mm FCRMX on my 628hybrid.
So it may help you I used the stock XR600 manifold and sudco make an adpater to go to the XR600 airbox. It all fitted perfect
I suspect you issue is that the XR650L airbox mouth is slightly smaller/bigger than the adapter?
Sudco def sell an adapter to go from XR600 airbox to FCR carb. Worth a shot
  • 2000dr650
Posted June 20, 2007 - 06:32 PM
no doubt..but im sure it'll cost me $60 or more for each ring....sudco, while they have great stuff, they're very expensive..im not leaking air .$2.00's of hose clamps will do for now
  • martinfan30
Posted August 20, 2007 - 03:55 PM
what pilot you running and at what elevation? is yours the slant body or straight body?
  • exaresix
Posted August 20, 2007 - 07:56 PM
You should check the parts fiche on the Sudco site to assure yourself that you are turning the correct screw. You may be turning something else.
  • exaresix
Posted August 20, 2007 - 08:06 PM
He will need the xr600r rubber manifold AND the aluminum screw-in throat to fit up with that manifold. Since he took this carb from another bike, he may not have the version that has the threaded front end that allows for use of the screw-in piece. As you state, he will also need the bolt-on rear adaptor to fit the air-box.
The FCR 41 fits into the xr frame nicely, the 41 FCRMX however is not a perfect fit. It requires grinding away a portion of the carb body to fit. As I recall, rmhrc630, that is what you had to do to make yours fit.
  • rmhrc630
Posted August 21, 2007 - 12:36 PM
Exaresix you're right - the back of the carb required some minor grinding - nothing a decent mechanic couldn't do.
I did it and figured the performance gain was worth the risk. Burned also confirmed there were no hidden cavities.
  • Natnewt
Posted March 03, 2009 - 08:43 AM
so you are using the straight body with and adapter? which adapter did you use?
  • stuntrider7x
Posted March 03, 2009 - 09:47 AM
Hi Im interested In putting one on my bike, what all do you need besides the keihin fcr41, What throttle and cables are needed.
  • Denn10
Posted March 03, 2009 - 03:09 PM
am i just that 'tarded and trying to adjust the wrong thing???:p
BELIEVE DAT!! you are a tard, turn that dard thing!!
  • Natnewt
Posted March 03, 2009 - 03:56 PM
cable and airbox adapter and the proper jets is all you need.
  • Research Rat
Posted March 03, 2009 - 04:44 PM
FYI this thread is 2 years old.
:p
  • Natnewt
Posted March 03, 2009 - 05:36 PM
yes and i referenced someone whoe still posts and has his bike
Washington
  • Hot  32 replies
  • Hot  60 replies
  • 9 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
