Do I have a head gasket leak?
4 replies to this topic
  • BoyceLaForest
Posted June 19, 2007 - 05:02 PM
I have a 83 honda XL600
The cylinder head shows what I think looks like a very small amount of oil in between the fins on the middle gasket... the bottom is fine and the valve cover is fine.. I cannot feel any air come out with my hand when I rev it up. The bike seems to run fine, how can I tell? Compression check or something even easier for free?
  • BoyceLaForest
Posted June 20, 2007 - 05:13 AM
I checked out the clymer manual, apparently there is a oil passage right where the leak is... the gasket must not be seated properly, the leak is so minor that I will ignore it for now.
  • BoyceLaForest
Posted June 29, 2007 - 08:05 AM
I torqued the bolt that holds the middle of the oil line to head.. leak gone!
w00t!
  • martinfan30
Posted June 29, 2007 - 08:41 AM
w00t!
this happened to me before my last adventure ride! i was freakn out till i retorqued the banjo bolt! i like to loosen it after an oil change while cranking over engine to get oil up top quicker.
  • Motosprtman
Posted June 29, 2007 - 10:29 AM
Good on ya for finding the problem and reparing it. As a side note, a leaking head gasket will usually result in rough idle and poor performance.
  • 4 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
