Stalls under Hard Braking
5 replies to this topic
  • d1ezel8
Posted June 18, 2007 - 08:54 PM
I ride an 06' WR450. How can I stop it from stalling itself out under hard braking. I have the clutch in and sliding into a corner and it feels like the chain is rocking back and forth then shuts off. it will even stall when braking, rolling down a hill.
  • JSanfilippo
Posted June 18, 2007 - 09:00 PM
The idle is too low.
  • Solo
Posted June 18, 2007 - 09:44 PM
and/or the float bowl level is way off.
  • gregwr450f
Posted June 19, 2007 - 04:31 AM
I vote for a low lying float.
  • Mutu
Posted June 19, 2007 - 04:43 AM
Are you using the rear brake? They are different to ride than the 2 strokes.
  • dazzabb
Posted June 19, 2007 - 06:40 AM
I had a similar problem on my '05 in that it would stall very easily at low throttle openings.
Turned out the mixture was too rich so I wound the fuel screw in approx 1/2 then 3/4 of a turn and that smoothed out the engine idle alot, which reduced but did not eliminate stalling.
Initially i wound up the engine idle to try to prevent the stalling but that just led to the bike "running away" from me on tight downhills.
Hope this helps
