Yz Exhaust cam and Hotcams Intake ?
5 replies to this topic
  • MountainMax
Posted June 16, 2007 - 06:01 PM
I have the yz exhaust cam for now but wondered if maybe i could use a hotcams intake exhaust with the yz exhaust cam, anyone do this? is there much difference in the stock and hotcams intake cams? I would use the hotcams exhaust however it it's even worse then the yz cam for the e start
  • SurvivorMan
Posted June 21, 2007 - 08:21 AM
how much difference is there in the intake cam from yz to wr? i know that the exhaust cam is worth the difference.
  • Mutu
Posted June 21, 2007 - 03:20 PM
Their exhaust cam is definately worth it, most of the gains are just from the different cam timing. :thumbsup:
  • Mutu
Posted June 21, 2007 - 03:31 PM
Max, the intake cam (and exhaust cam) has a little more lift and more duration. This means the valves are open a bit longer. Definately visable difference.
Is there much difference over stock? Don't know...... never compared just the intakes. I have read in a mag once that roughly 60% gains come from intake. Makes sense seeing it is providing more air/fuel charge.
Difference must be noticable though, seeing as hotcam set makes ~3hp more top end over YZ cam set.
  • SurvivorMan
Posted June 22, 2007 - 06:44 AM
The hp gains sound great, but i do like the estart. hopefully, someone figures out the estart problem with their hot cams (maybe the guys at Hot Cams will), otherwise i will just keep it stock.
  • xr250ryder
Posted June 22, 2007 - 10:04 AM
From what I've heard the onyl reason the e-start wont work is when you combine Hotcams with 13.5:1 or 13:1 Compression. If you have 12.3 or 12.5:1 It should work fine.
