Smog Removed Now Idle Hangs Up
3 replies to this topic
  • GseMech
Posted June 14, 2007 - 09:18 AM
Just finished removing the smog equipment from my '04 650L using the kit from Baja Designs. I followed the sequence laid out on the XRs Only website as it was the same as mine. I now find that the idle hangs up momentarily before settling down. Before the smog removal this was never a problem.The bike is otherwise all stock. Any suggestions?:thumbsup: :busted: :thumbsup:
  • captb
Posted June 14, 2007 - 09:30 AM
On my 650R I just richened the idle mixture, it's dead stable now and no decel popping. On my 650L years back I had rejetted and removed the smog stuff at the same time it was fine.
  • martinfan30
Posted June 14, 2007 - 10:52 AM
maybe you should check your throttle cables. maybe they were disturbed somehow during the job.
  • txmedic
Posted June 14, 2007 - 06:14 PM
What you describe is sometimes an indication of a lean carb setting.
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
  • 9 replies
  • 17 replies
