Choice of handlebars for 650R?
16 replies to this topic
  • Butta
Posted June 14, 2007 - 06:31 AM
Just bought an '01 R with bent stock bars. Anyone have any suggestions for some handlebars that are a bit taller? I'm 5'10" and am used to a YZ450, so the stock XR bars feel pretty low. I like the width, though.
Thanks!
  • pigryder
Posted June 14, 2007 - 07:26 AM
get the CR high bend :thumbsup: , I love them and have them on all my bikes
  • BajaBoundMoto
Posted June 14, 2007 - 07:34 AM
To do it correctly you need to get the bars farther forward and higher, the top clamp sucks.
There are many ways to do this including new top clamp:thumbsup: , risers that fit the stock top clamp, then many choices of stabilizers, etc... You just need to figure out how much $ you want to spend and what you really need.
  • Supplicate
Posted June 14, 2007 - 08:09 AM
http://brpit.com/pag.../sub_mount.html
:thumbsup: :thumbsup: from me :busted:
  • tdamore
Posted June 14, 2007 - 08:33 AM
The CR Highs are the hot ticket but as everyone else said, if you are taller than 6 feet you are gonna want to move them forward a bit as well.
  • MikeZ
Posted June 14, 2007 - 11:53 AM
I have Rental CR Hi's that are bent and have been looking for a lower cost option. It seems the different manufacturers definition of CR Hi is different across the board.
Some higher, some lower, some with more rake.
Check specs before buying.
-Z
  • HawkGT
Posted June 14, 2007 - 01:39 PM
I'm 5-10 and am happy with my Pro-Taper SE CR high bends. I ride standing up a lot and haven't ever found them too short. Ergos are kinda a personal thing though.
  • hill5150
Posted June 14, 2007 - 05:28 PM
Tapers w/ the BRPIT forward Scott's, I'm 6' 2"...........:thumbsup:
http://img.photobuck...xr6fiddy007.jpg
  • tdamore
Posted June 14, 2007 - 07:45 PM
How about some details on that GPS mount setup? I have an etrex I want to throw on my pig. Do you have it hardwired in or just running it off the AA's? Sorry for the thread hi-jack :thumbsup:
  • ganshert
Posted June 14, 2007 - 08:59 PM
I run CR-HI on a Scott's sub mount. I'm 6'3" and this works well for me. I stand up 80% of the time when off road.
I had alot of problems getting GPSs to work well on thumpers. they don't like the vibration at all especially when you are using battery instead of hardwire. I killed 3 GPS units on my KLR. I finally shelled out the bucks for a good vibration damping mount and haven't had any issues since.
I'm running a 60CSX on batteries with a Touratech mount attached with Ram mount short arm and U bolt on the handlebars.
http://www.touratech...BC94F4250758FA6
  • thumper605
Posted June 15, 2007 - 05:24 AM
I like the Travis Pastrana these handlebars have a 4.75 rise on them.
They are the tallest handlebars that I know of.
  • Butta
Posted June 15, 2007 - 06:21 AM
Thanks everyone for the overwhelming response. I am definitely going to do a little research on the CR Hi's, and see what the specs are. I really don't care to spend the money on a new top clamp, so I'll try to find something that can bolt right on to the stock one.
  • hill5150
Posted June 15, 2007 - 06:55 AM
The GPS is working flawlessly on the AA battery setup, I can get 8-10 Hours out of it, Duracell of course...:thumbsup: no hardwire, the mount I got at Touratech it's a RAM mount works great.............
  • pburke
Posted June 15, 2007 - 01:09 PM
I'm running the same thing he shows in the picture - 60csx with RAM mount (about $35), all on AA, 20 hours battery life usually. Haven't had a problem on the first thousand miles with that setup.
For bars, I am about to install CR hi-bends on the BPR scotts mount (under bar). I'm 6'2" and the stock setup was painfully unusable for standing up
  • drop
Posted June 15, 2007 - 02:02 PM
You can run fat bars/protapers with the stock triple clamp if you use an adapter. Severeal companies make them including ProTaper. You can find them in the TT store. That's what I run. They also raise the bars up about 3/8" which is a big help.
  • tdamore
Posted June 16, 2007 - 07:42 PM
Cool. I had it hardwired on my 450x but that had a battery. I'll just run it off of some rechargeable AA's.
  • ganshert
Posted June 19, 2007 - 09:40 AM
lots of us have had issues with the 60CSX Ram cradle not holding on to the GPS when the riding gets rough
I've had it spit mine out into my lap several times. I think it happens when the mount gets older and doesn't hold the tension like when new.
that's why I went with the locking Touratech mount
more here; http://www.advrider....ad.php?t=222522
  • Hot  186 replies
  • 4 replies
  • 17 replies
Washington
  • Hot  32 replies
