DRZ Speeds - list yours
181 replies to this topic
  • sliderscraper
Posted June 14, 2007 - 05:22 AM
Hello my fellow Dual Sport DRZ'ers... plese post up your answers to the below:
1) what's your average cruising speed (on open roads)? :thumbsup:
2) What's the highest top speed you've had out of your DRZ? (be honest) :thumbsup:
  • colorado4wheeler
Posted June 14, 2007 - 05:26 AM
On my E I cruise at 70-75mph. I have seen 82mph IIRC. These are GPS speeds.
  • WoodButcher
1) dirt or paved?
2) Indicated on speedo or GPS?
  • Roadracer Al
Posted June 14, 2007 - 05:31 AM
DRZ 400 SM -- indicated highway cruise speed 70 mph, actual GPS speed 64. Top speed indicated 94, didn't have GPS with me at the time, but probably in the 85~88 range.
Uncorked exhaust, 3x3, JD jet kit.
  • eluno03
Posted June 14, 2007 - 05:32 AM
DRZ SM
1) what's your average cruising speed (on open roads)? : Highway 65-70 Mph
2) What's the highest top speed you've had out of your DRZ? : 93 Mph (Speedometer)
  • Regalman
Posted June 14, 2007 - 05:36 AM
1) Haven't had the SM wheels on all summer.
2) 103 indicated on a huge downhill with stock everything (including trailwings)
  • Ladicius
Posted June 14, 2007 - 05:38 AM
1.) I try to keep it around 60ish, 70 or so on highways
2.) 88 mph
Both speedo readings.
All stock.
  • sliderscraper
Posted June 14, 2007 - 05:51 AM
Mine, by the way, is...
1) 53 MPH cruising (there a nice sweet spot there)
2) 70 MPH top speed - not really tried any faster yet. I will now!
All on stock bike (running road legal knobblies)
Cheers
Slidey
  • ajd187
Posted June 14, 2007 - 06:36 AM
1. 50 mph crusing
2. 77 mph
Both indicated on the speedo.
  • drzfool
Posted June 14, 2007 - 06:56 AM
1. Cruise at 65-70mph.
2. Top speed 97mph. (drag limited, not bouncing off the limiter.)
Indicated by stock speedo. Probably more like 90 mph top speed actual.
'05S w/FCR, 14/43 gears and teraflex knobby!
  • smcalpac
Posted June 14, 2007 - 07:22 AM
70 mph
98.6 mph
My speedo is a programmed (AND ACCURATE) TrailTech unit.
On a 130/60/17 with (edited) 16/39 gearing. (That used to say 13/39)
  • mkorn
Posted June 14, 2007 - 07:30 AM
Most of the roads around me are 45-55 mph's so i run 5 over what the posted is hoping that i am close to posted.
Top speed on the speedo for me was 86 indicated. on an S all stock
  • Killer B
Posted June 14, 2007 - 07:40 AM
TOP SPEEDS:
87 street (level)
72 gravel (level)
3x1 Airbox mod
Kenda K270 (5.10) rear
otherwise stock
I don't consider my bike a "cruiser",
so I don't cruise at any particular speed.
  • William1
Posted June 14, 2007 - 07:53 AM
Highway and deserted back roads, 75~80
Max speed was 100 and still climbing. Truck wind blast made going faster a litle unsettling.
These are INDICATED speeds via the precision speed device provided as standard equipment on my 06 SM.
Further worth mentioning mods as that affects it greatly.
FCR with K&N
E Cams
E Headpipe
16/41 gearing
Bike lowered 2.5 inches
  • jaysunm
Posted June 14, 2007 - 08:44 AM
crusing 88 (sweet spot)
max seen 99 (down hill)
04 S converted to SM
SM speedo
FRC/K&N
Hot Cams (in/out)
15/38 sproket
  • 07400sm
Posted June 14, 2007 - 09:17 AM
Stock speedo:
Cruise speed gravel: 50mph.:thumbsup:
Cruise speed highway: 60mph.
Cruise speed freeway: 75-80mph.
Top speed on freeway: 102mph :busted: (not downhill, in full tuck trying to hide behind the "fairing"). never hit rev limiter ever i don't think.:thumbsup:
Mods in garage.
  • danmorgan
Posted June 14, 2007 - 09:31 AM
1. Motorways and dual carrageways cruise around 75
In the back lanes i really get below 85 (thats were the fun is)
2. 106 fairly stock, since the cams and big bore only hit 104 but il be taking it to the same stretch of road soon so il see if its got any faster but it depends on the wind if theres a slight breeze sometimes can only reach 90 odd
  • Plane Dr
Posted June 14, 2007 - 09:35 AM
I cruise at 70-80 mph
Top speed 99 mph
Both are GPS. Next decent oportunity it should run 100+ the top speed was prior to the hot cams. Although the GPS did indicate a top speed of 260 mph in the statistics, but I think that might be inaccurate.
  • 07400sm
Posted June 14, 2007 - 09:37 AM
Plane DR. The PW in your avitar looks like it might beat me:cry:
  • supermotogreg
Posted June 14, 2007 - 10:42 AM
70 mph
98.6 mph
On a 130/60/17 with 13/39 gearing.
Average cruising speed: indicated 70 (actual 65 @ about 5,500 rpm)
Top speed: indicated 96 (actual 89 @ about 8,000 rpm)
This is on a SM with a completely stock engine carb and airbox, stock tires, modified exhaust, and 16/38 road gearing.
Greg
Help with exhaust choosing by GearHeadGumbie
  • 7 replies
Desert SuperMoto by alpha_nett
  • Hot  60 replies
Used DRZ400 or DR650? by dnb123
  • Hot  67 replies
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
  • Hot  58 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
