Rear preload-confused!
6 replies to this topic
  • dazzabb
Posted June 12, 2007 - 05:37 PM
I just changed the spring on the shock to a softer spring.
After installing it with 247mm of spring pre-load when I pick up the back of the bike the is NO movement, the rear end comes straight of the ground.
Does that mean I have too soft a spring, too much pre-load or what?
I checked the race sag and it is 100mm and the static sag is 10mm, but to be honest I'm no really sure what that is telling me!
Cheers
  • pkcof
Posted June 12, 2007 - 06:14 PM
Cheers
you just said that the 'static sag' is 10mm ??
  • Murray Dorward
Posted June 12, 2007 - 09:52 PM
The static sag should be between 30-40mm. If your sag is 100mm and your static sag is 10mm then your spring is too soft. Go to www.mx-tech.com and use there spring calculator to work out the spring rate that you require to suit your weight with kit on.
Cheers
Muz
:thumbsup: :busted: :thumbsup:
  • pkcof
Posted June 13, 2007 - 10:29 PM
Cheers
Muz
FIRST = set your race sag ... (105mm ~110mm) << as a rule of thumb
THEN = measure your static sag and let us know what that measurement is ??
Then we can let you know the next move ...
cheers
  • dazzabb
Posted June 14, 2007 - 05:05 AM
PK,
OK I measured the race sag at 103 mm and the static sag at 29mm.
These is the best combination I can come up with after playing with the pre-load this arvo.
If I increase the pre-load to reduce race sag to 90-100mm as per the manual then the static sag decreases well below 29mm.
Basically looks like I have too soft a spring, but to be honest I'll probably live with it as it's not far off the recommended specs.
Have to try and compensate with the damping.
  • Murray Dorward
Posted June 14, 2007 - 10:26 AM
You are border line, but if you can live with it is 99% better than a 10mm sag. You actually need the next spring up, but you should survive.
Cheers
Muz
  • RJB
Posted July 30, 2007 - 05:15 AM
PK,
Despite what the manual says, has anybody found the sag setting that works best on the 07 WR450? Would love to get mine right
