Cam chain specifications
4 replies to this topic
  • dmwaterdog
Posted June 12, 2007 - 03:54 PM
Has anyone come across specs for cam chain wear limits, such as pin to pin length for a given amount of links? The manual says to check for wear/damage - real useful.
  • Big Tim
Posted June 12, 2007 - 04:32 PM
I always pull on the chain as it rolls over the gear to see if it pulls off of the cam gear. Mine never really pulls off of the gear. I assume someday it will. I also assume that the engine will let go before it gets to that point.
PS I have been told this by many old timer Motorcycle techs.
  • David37
Posted June 12, 2007 - 08:34 PM
Stock cam chains are fairly cheap, less that $20. If you think your cam chain is worn, IMO I would just replace it, cheap insurance. If you're looking for wear patterns, I would look at the cam chain sprockets for excessive wear patterns.
  • dmwaterdog
Posted June 13, 2007 - 07:17 AM
Who carries cam chains for $20 (or less)?
  • David37
Posted June 13, 2007 - 07:05 PM
Check out the TT store or North County Yamaha (NCY).
