13.5-1 piston on pump gas?
5 replies to this topic
  • GBC
Posted June 11, 2007 - 06:55 PM
Will a 13.5-1 piston run on pump gas in my 2000 426?
  • 642MX
Posted June 11, 2007 - 07:10 PM
Of course it will, but it may ping. If you hear it pinging then you need to blend some race fuel with pump fuel.
  • GBC
Posted June 12, 2007 - 07:22 AM
Well I dont want to run race fuel at all. I know we can run 13.5 pistons just fine on pump gas in the crf450 but I was wondering if the 426 can do it as well.
Posted June 12, 2007 - 07:49 AM
Under most circumstances, yes you can. Only if the engine is lugged hard at a lower rpm will it ping on reasonably good pump gas.
  • whyzee426F
Posted June 12, 2007 - 08:05 PM
...so how much actual benefit is there to running a 13.5:1 piston?
  • 642MX
Posted June 13, 2007 - 09:30 AM
Increased torque from idle to mid-range. They don't do much on the top end, but from the bottom thru the mid range they rip. I wouldn't rebuild my motor without one. :thumbsup:
  • Hot  38 replies
  • Hot  113 replies
  • Hot  36 replies
  • Hot  47 replies
  • 10 replies
