Stalling at partial throttle
1 reply to this topic
  • dazzabb
Posted June 11, 2007 - 08:27 AM
My WR450 stalls often at partial throttle, like when just about to pull away from the lights or when negotiating a really tight offroad section.
What's the most likely cause / solution?
The plug colour when running off idle is pretty dark brown. At anything other than partial throttle there's no drama.
Also, would installing a PMB silent insert be a possible cause of this?
Cheers
  • Solo
Posted June 11, 2007 - 10:47 AM
Mine had similar issues and it turned out to be the accel pump diaphragm.
I'm sure it's a carb issue- you just need to track it down.
