XR650L Front Sprocket?
3 replies to this topic
  • malevolent73
Posted June 09, 2007 - 12:47 AM
Does anyone have, or know where to get a larger FRONT sprocket (16 tooth)
for an L... or if it will even fit on the bike??? I find its geared just a bit too low for street riding, which is primarily what I use it for... also revs a little high at highway speeds. I just use it to get to work and back, and fun cruisin!
I have a 650R just for the dirt. I would prefer to just change the front if possible... any ideas???:thumbsup:
(I already spoke w/ Nate at Ironman, they don't carry one)
  • sephy
Posted June 09, 2007 - 03:43 AM
http://sprocketspecialists.com/ is a great site.
I dont know about going up in the front (the site says the range is 13-15 and stock is 15), but you can always go a few down in the back to do the same thing (see sprocket site ;P )
  • goblin127
Posted June 09, 2007 - 04:42 AM
I'm thinking the 15 is the largest that will fit in there.
  • InternalCombustion
Posted June 09, 2007 - 05:37 AM
The source I use for my 650R is Sprocket Specialists. They make sprockets for tons of models and were the only source I found for a 16t for my R.
Cannot say if a 16t will fit on your L, just take off the case-guard if you have one and eyeball it. Measure the diameter of your 15t and multiply that by about 1.07, since the 16t (if one is available) will be about 7% larger in diameter.
Or, you can keep it simple and just check Sprocket Specialists website for a 16t. If they don't show one, odds are its because a 16t won't fit.
Good luck.
Honda XR650L 2016
  • 0 reviews
  • Hot  186 replies
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
