XR650R Rear Brake Fade
1 reply to this topic
  • lucky13
Posted June 04, 2007 - 08:20 AM
I have an 01 XR650R that has both SM and Dirt set ups. I recently went back to the SM Setup and when I went for my first ride, realized I had no rear brake. I drained and bled the system to the point it was shooting out fluid when I hit the brake in the bleeding process.
Well, I went for another ride and after after 2 or 3 taps of the rear brake it faded again.
Any ideas? I checked the brake pads, fluid level, whether or not they are dragging... everything seems to be ok.
:thumbsup: :) :ride: :ride: :ride: :ride:
  • Firelyle
Posted June 04, 2007 - 11:21 AM
Just a guess..but it sounds like you have lost a piston seal causing you to lose pressure in the caliper. If you bled the brakes correctly (as I'm sure you did) then most likely you are going to need a caliper rebuild or a least check to see why the caliper pistons are sticking or just not moving. Not hard to do...just go slow and keep it very clean!
Good luck
Washington
  • Hot  32 replies
  • 22 replies
  • 3 replies
  • 4 replies
Honda XR650L 2016
  • 0 reviews
