maintenance on a WR
4 replies to this topic
  • Bshaips
Posted June 03, 2007 - 06:10 PM
i dont know a whole lot about 4-strokes since i had 2-smokes. what other kind of maintenance should i do other that change the oil regularly and how often do you guys do other maintenance on your bikes. BTW its a 99 WR400. thanks
  • MaxPower
Posted June 04, 2007 - 03:15 AM
  • SRT426
Posted June 04, 2007 - 03:35 AM
My service schedule:
1 - Check valves once a year - unless bike is hard to start, then check during next oil change
2 - Oil change every 5 hours/ Change filter every other oil change
3 - Air filter every 10 hrs unless it needs it sooner
4 - Clean carb every 6 months or so
5 - Check and clean oil screen (behind skid plate) once a year
6 - Change plug once a year
7 - Change coolant once a year
8 - Clean and lube chain before every ride, adjust as necessary
9 - Check nuts and bolts before every ride, they like to come loose
Thats basically what I do to my '01 YZ426. Hope this helps.
  • Bshaips
Posted June 05, 2007 - 07:04 AM
the link didnt work but i know how to do every thing except adjust the valves so if you go into detail or give a link or something that would be great. Thanks
  • 04WR450man
Posted June 05, 2007 - 02:58 PM
Look at the maintenance section of this link, loads of helpful info :thumbsup: :) :ride:
