gearing advice
9 replies to this topic
  • mtrider1
Posted June 03, 2007 - 12:42 PM
Hey there,new to the site...love it.
Just bought an 01 yz426 and while i really love the power,I've found that the standard 48 tooth rear sprocket is wwwaaaayyyy too tall in the rough stuff.What sprockets are you guys running for off-road riding?I was thinking about a 53 tooth,I usually ride in rocks and crap so a little grunt is what I'm looking for.Thanks for any advice.
Posted June 03, 2007 - 03:16 PM
Search a little. Question's been asked and answered many times:
http://www.thumperta...421#post1598421
  • 642MX
Posted June 03, 2007 - 04:23 PM
The standard rear sprocket is a 49 tooth. I use stock gearing for woods and MX. :thumbsup:
  • SRT426
Posted June 03, 2007 - 10:49 PM
For the tight stuff run a 13/50 combo. It gives great low end and still has enough top end in case it opens up a bit. I've got the same bike ('01 426) and I love that combo. I like it because you can use second gear instead of feathering the clutch in first and overheating it. But if you need the real low end granny type of gear you still have 1st to drop down to.
  • OUCR250R
Posted June 05, 2007 - 11:26 AM
I usually drop a tooth in the front. This is easy because you can usually get away with using the same length chain as your 14 tooth stocker. That way you can easily swap between mx/woods gearing.
  • creeker
Posted June 05, 2007 - 11:36 AM
I found the stock gearing, 14/49, to be geared a little too high for tight stuff, but I had an extra 13 tooth lying around and tried it and it is geared WAY to low... I mean, 60mph would be a high speed with this setup! :thumbsup:
I have also tried 14/50 and, to me, it is about perfect for trails and what not.
  • 700MX
Posted June 05, 2007 - 07:48 PM
SPROCKETS ARE CHEAP
Get a few, play around and gear to the track and your skill level.....everyone is going to like different options!
700
  • felix 222
Posted June 05, 2007 - 07:58 PM
i use 53 and it gets the job done pretty well:thumbsup:
  • mtrider1
Posted June 06, 2007 - 05:48 AM
Thanks for your thoughts.(my bad on not searching first)
gotta a couple options lined up and will try them this weekend on the mountain.
hopefully i'll be able to keep my new clutch intact with lower gearing.
  • mtrider1
Posted June 06, 2007 - 04:59 PM
quick update...
bought a 13 countershaft today and was gonna install it.got things apart and much to my chagrin the previous owner had installed a 15 tooth sprocket...back i go for a stocker and i'll tell ya,it's a world of difference.sometimes i can be a real dumbass by assuming things.thanks again for all your thoughts.
  • 9 replies
  • Hot  28 replies
  • Hot  36 replies
