Changed Brake Line, Now No Brakes?
6 replies to this topic
  • twenty34
Posted June 02, 2007 - 07:11 PM
So I changed to a steel braided line front brake line, but it won't bleed now? I can pump the lever for hrs and it won't build up any pressure to bleed them. I tried everything. All the bolts and bleeder valves are closed, but this one has me stumped. I even went back to the stock cable and it still doen't work now.
I had a front brake before going through this exercise, now I can't even get it back to what is was before I started. :thumbsup:
Posted June 02, 2007 - 08:14 PM
Try this:
http://www.thumperta...701#post4680701
Alternatively, if you can find any kind of syringe that will hold 20-30 cc or more, even a squeeze bottle, and a piece of clear hose, you can pump fluid up from the bleeder. Do that with the M/C cap off, and be sure to avoid pumping any air up with it.
Right now, there's a really huge bubble in there that won't allow anything to push it out of the way. Once you can get it to move, gravity bleeding will usually make short work of it; just open the bleeder and pour fluid through it until you don't see anymore air.
  • axman2292
Posted June 03, 2007 - 10:30 AM
Rick,
I just had to rebuild my master cylinder due to the same problem....(not getting presure) I did the reverse bleed and it worked well. I first took the caliper off so I could hold it up. Just push fluid through 4-5 times..as the M/C fillls suck it out with another syringe. After each bleed close the bleeder screw. If you still dont have luck..you may have problems with the M/C..the rebuild kit is only 20 bucks and 20 minutes to replce.....Good Luck. AXMAN
  • MaxPower
Posted June 03, 2007 - 01:02 PM
[COLOR="Green"]you didnt happen to use DOT5 brake fluid did you?[/COLOR]
  • twenty34
Posted June 03, 2007 - 02:07 PM
Rick,
So I almost went the rebuild route and even M/C, however, I used a bleeder pump and that quickly solved the problem. Sucked the fluid through the bleeder valve on the caliper a few times and refilled the M/C while doing this process and the brakes quickly came back to life. :thumbsup: :) :ride:
Thanks for the help.
p.s. a M/C is $120.
  • 2wheels-drz
Posted June 03, 2007 - 02:32 PM
wah?? that would not make a diff....i run dot5.1 road racing fluid in my motocross master cyclinder..
what you need is a length of clear breather pipe and syringe, and simple draw the fluid out from the bottom caliper, just leave the bottom bleed nipple open, cap of master cyclinder and don't touch the lever. just keep topping up the fluid. once you get pure fluid and no air, close the bleed nipple, pump until u get alittle pressure. hold pressure (i.e. lever in) and get a friend to open and close the bleed nipple...repeat the pump up and release until u have a brake..should not be more than 10times...
this method always works for me.. i never go the forcing fluid through the bleed nipple route cause i'm always a afraid it will leave a airbubble in the middle of line somewhere. stupid i no, but when it comes to sumo i like to have nothing but confidence in my brakes
goodluck, hope this help.
EDIT:
DO'H.......just saw u already got it sorted....o well i do try..
  • axman2292
Posted June 03, 2007 - 07:00 PM
Rick....Sweet!! You got it going...I know how you felt..I was so bummed out when I was having these problems...just a pain in the butt. Good luck out there.....AXMAN
  • 10 replies
  • Hot  38 replies
  • Hot  28 replies
  • Hot  50 replies
