Cold Hearted Beastie
6 replies to this topic
  • jvw1952
Posted June 02, 2007 - 05:16 PM
Just bought an '03 XR 650L with 309 miles on it. It starts right up with the choke in the first notch position. I can't take the choke off until I run it 3-5 miles! If I do it stutters and chokes. After what I consider a way extended warm up, it runs great. Is this normal?
  • Bibleman
Posted June 02, 2007 - 05:30 PM
Yes and no. Yes for the stock set-up, but you'll want to do a search for "Daves mods" and do them. It will make your bike run RIGHT!
  • ImStuck
Posted June 02, 2007 - 05:58 PM
depends....you might want to clean the jets off if its been sitting for a while...
take em out and try to blow compressed air through them, if one has what you believe to be a restriction or blockage, clean it out...
but, i have no clue what your bike is actually doing...
just my $0.02
  • vaughn
Posted June 04, 2007 - 04:53 AM
Try adjusting your carb needle clip down one notch (richen/raise needle).
  • martinfan30
Posted June 05, 2007 - 10:10 AM
or get a pumper!!!!:thumbsup: :) :ride:
  • cleonard
Posted June 05, 2007 - 11:42 AM
Since the mileage is so low, the bike must have sat for years. Over time the gas in the carb evaporates and leaves a varnish like coating. This stops the gas from getting through. Take the carb out and clean it. Spray carb cleaner through all the jets and passageways. It sounds like the pilot jet is clogged up some.
If you do "Dave's mods" the bike will run a lot better. You will like the results. The bike comes with a very lean pilot jet. Part of the "Dave's mod" is a richer pilot jet.
  • jvw1952
Posted June 11, 2007 - 05:52 PM
Lots of good advice. I was afraid the carb might have to come off, but now I am sure.
Thanks!:thumbsup:
  • Hot  148 replies
  • 0 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  60 replies
  • 7 replies
