Anyone bother to turn the petcock off?
38 replies to this topic
  • Bibleman
Posted June 02, 2007 - 04:43 PM
Just curious if it's really necessary. When I do, nine times out of ten I forget to turn it back on and stall the bike.:thumbsup:
  • jvw1952
Posted June 02, 2007 - 05:05 PM
I haven't turned one off for years
  • ImStuck
Posted June 02, 2007 - 05:52 PM
same here, and it hasnt been bad to me... but, i need to rebuild it, so, that could say something... but its 13 years old.
  • Timmerz
Totally against the advice of all my buddies, mine stays on unless it's going into extended storage, like more than a few days or so.....
  • LeadDoggy
Posted June 02, 2007 - 07:05 PM
After I get done riding for the day, the fuel valve gets turned off.
  • Potts228
Posted June 02, 2007 - 07:46 PM
I always turn them off when they are on the trailer or in the back of a truck. The bouncing can cause fuel to run into the engine and also out the overflow tubes. The end result can be a hard to start engine and lost fuel.
  • InternalCombustion
Posted June 02, 2007 - 09:01 PM
I used to not do it, but just as a discipline thing I now do it on all my bikes. Helps me stay focused on ALL the safety, pre-ride checks, like "tires, chain, lights, oil" etc.
Getting old, I guess.
(But like they say, "Getting old beats not.")
Ride safe.
  • bork
Posted June 03, 2007 - 05:00 AM
I always turn it off, always have on all my bikes. Habit I suppose.
  • captb
Posted June 03, 2007 - 05:43 AM
Allways on dirt bikes, my street bikes have auto shut off. I don't need any surprises.
  • zodran
Posted June 03, 2007 - 06:44 AM
Yep, I usually shut if off and let the bike run long enough to empty the float bowl. I got in the habit when I had a CR500, always seemed to start a little easier with fresh fuel in the bowl.:thumbsup:
  • wheelnut46
Posted June 03, 2007 - 08:34 AM
+1
Also good if I can't ride unexpectedly for a while.
  • Jack Roberge
Posted June 03, 2007 - 10:36 AM
I never turn mine off no matter how long it sits. I do turn it off when I trailer it as gas will leak out of the overflow hose.
  • Firelyle
Posted June 03, 2007 - 10:46 AM
Turn off my street and dirtbikes....I don't know if it really matters but learned to ride that way and have always done it.
  • exaresix
Posted June 03, 2007 - 11:59 AM
There are numerous methods of dealing with the bike that is not being used for a while. No method has been universally endorsed by anyone with authority. I have done everything from nothing at all to draining the tank and float bowl and spraying carb cleaner in the empty float bowl afterwards. Eddie Sisneros recommends using Stabil in the gas and leaving the float bowl full. The petcock itself does not seem to be a big issue with anyone.
  • desmo900
Posted June 03, 2007 - 01:04 PM
here in southern california, i have to to turn off the valve and drain the bowl Everytime i ride or the crappy gas here will leave Green crusty deposits in the carb and plug the float valve .
not only my bikes, but the lawn mower and edger are the same way.. Brand new honda mower used it for the first time and by the next weekend. the carb was clogged up with green.
  • goblin127
Posted June 03, 2007 - 01:28 PM
You guys are probably on the ethanol like we are. Terrible stuff for carbs. Outboard motors are having a hard time of it. As far as the petcock goes it gets shut when ever the bike is going to get parked that doesn't include running into a store or something of that sort.
  • ImStuck
Posted June 03, 2007 - 05:22 PM
I KNOW!!!!!
SHI**Y GAS!
pulled out the jet + float bowl drain plug, covered in green nastyness.
  • jbird710
Posted June 04, 2007 - 06:19 AM
Just as a habit, I always turn mine off after riding including between practice sessions on the track.
  • Denn10
Posted June 04, 2007 - 07:37 AM
+1 only if im not riding in on a regular basis. The fuel that might evaporate off in a day or so is not even gonne be noticeable to your wallet. I have never seen this cause a problem.
  • gabriel
Posted June 04, 2007 - 08:34 AM
I turn mine off but only becuase i am anal about things...i really don't believe you have to unless you are having carb float problems (old bikes who's owners don't maintain the carb).
