extra valve noise on xr 600r is this normal???
5 replies to this topic
  • banshee power
Posted May 31, 2007 - 02:13 PM
hello guys.
I just purchase a 95 XR600R dual-sported and have been noticed a lot of extra valve noise.:)
is this normal?
the bike oil measure its above the full mark on the stick
start´s allright and pull´s like hell.
Will this be enough to tell if the engine is damaged?:thumbsup:
any info on this matter?
Thanks
  • martinfan30
Posted May 31, 2007 - 02:23 PM
check the valve clearance.
  • Beerad
Posted May 31, 2007 - 02:35 PM
Yup, check the valve clearance first, then if it's whithin spec, and it STILL makes noice, most likely you'll need to replace the rocker arms and cam.
Most likely though it just needs to be adjusted. :thumbsup:
  • banshee power
Posted May 31, 2007 - 03:23 PM
tank´s guys for your help:applause:
  • cleonard
Posted May 31, 2007 - 10:22 PM
All the RFVC engines have two part rocker arms. All that extra moving metal makes a bit more noise than a normal one part rocker arm even when everything is adjusted correctly.
  • bork
Posted June 01, 2007 - 05:43 AM
Make sure you are getting oil to top. verify thru the top external metal line. Is the filter in backwards. Easy to do & will dust you top end with no oil.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
  • 9 replies
  • Hot  186 replies
  • Hot  29 replies
