Chain adjustment problems on DRZ400
5 replies to this topic
  • nsxdude
Posted May 29, 2007 - 03:42 PM
Anyone else have problems adjusting the chain tension on there DRZ?
I have a DRZ400S with Excel rims (supermoto setup) and I have had a lot of problems getting the chain adjusted. It seems like the axle continues to slip thus my chain tension gets REAL lose. On my sportbike I had a bolt that youused to adject the tension, on the DRZ they have a built in tension controller that does not seems to work very well. Am I missing something? Is there a trick to getting this to stay? I am using 42 lbs/torque per the DRZ manual. Any help would be greatly appreciated !
  • Kicks
Posted May 29, 2007 - 03:48 PM
Is the slip after riding, or is this a problem with setting the chain tension prior to riding?
Kev
  • Neil Claydon
Posted May 29, 2007 - 03:52 PM
The S tensioner works fine, provided you do it properly;)
Once you have the tension right, and before doing the axle nut up, you must push the wheel forward so the serration's on the adjuster cams locate on each of the to pegs in the swing arm, one each side.
Important, while doing the nut up (right side) you need to hold the axle (bolt) on the left side to stop it turning, if you fail to do this the adjuster cam will let the tension off.
Neil. :) :ride: :bonk:
  • sryder
Posted May 29, 2007 - 05:41 PM
...I am using 42 lbs/torque per the DRZ manual. Any help would be greatly appreciated !
I believe proper torque is 72.5 ft-lbs per Service Manual.
A trick I learned is to put a rag between the chain and rear sprocket. Then turn the wheel. This will cinch rear axle forward, against the cams. Then tighten the axle nut to 72.5 ft-lbs and insert the cotter pin.
My guess is you are not cinching the axle to the adjuster cams while you tighten the axle nut, and you are not tightening the axle nut nearly enough to the proper torque.
  • nsxdude
Posted May 29, 2007 - 07:49 PM
should the tension adjusters match? i.e. - number 6 position on the sprocket side should also be 6 on the brake side?
  • GOF1
Posted May 29, 2007 - 07:59 PM
In a perfect world both sides should match, but check the chain alignment to be sure. A straight edge(string) from the front of the front sprocket to the back of the back sprocket should touch the same on front and rear of both sprockets. If not adjust one side or the other till it does. Then keep track of the difference for future adjustments.
Drz400E aus spec E and mrd exhaust by GearHeadGumbie
  • 0 replies
Used DRZ400 or DR650? by dnb123
  • Hot  67 replies
Desert SuperMoto by alpha_nett
  • Hot  60 replies
2003 Drz400s struggling at 55 mph? by kingbluey
  • Hot  65 replies
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
