wr250 shock on a WR450?
3 replies to this topic
  • Oldmxer
Posted May 29, 2007 - 07:00 AM
I have an emergency. A buddy is leaving for Colorado and his shouck is leaking on the 2003 WR450.
Does anybody know if a shock from a 2003 WR250 will fit.
It looks the same, but I did not want to pull both if I can get an answer here first.
Thanks
  • marty b
Posted May 29, 2007 - 01:25 PM
look at the part numbers onlin
  • old man dan
Posted May 29, 2007 - 01:36 PM
If it saves a riding trip I would go for it. I would probably keep the spring from the 450 on the 450 though. The valving might be a little different I doubt it would be much.
  • Oldmxer
Posted May 30, 2007 - 05:28 AM
Shock part numbers are different, BUT the top and Bottom bolts parts numbers were the same. So I went ahead and moved it.
I am sure the valving is just different is why the shock numbers are different.
It did bolt right up, and the bodies look identical.
IE: it worked and the trip will go on as planned.
