compression/stroke/bore calculation question for gurus
14 replies to this topic
  • machman
Posted May 28, 2007 - 12:26 PM
Engine 1: XR600R
bored out to 101mm
stroke is 80mm
stock compression is 9:1
new compression with JE piston is 10.6:1
Engine 2: XR650L
bored out to 101mm
stroke is 82mm
stock compression is 8.3:1
new piston is same JE piston from above
Given that these two pistons are interchangeable, what would the new compression ratio be in the XR650L engine with the above mentioned high comp piston for the XR600R?
  • exaresix
Posted May 28, 2007 - 05:26 PM
My calculations say 9:1
  • machman
Posted May 29, 2007 - 06:08 AM
Seriously? I would have thought it was higher than that.
Anyone else able to do these calcs?
  • XR650L_Dave
Posted May 29, 2007 - 02:19 PM
I'm not sure you can without the head CCs.
maybe this way, lemme see:
stock XRL:
Bore and Stroke: 100.0mm x 82.0mm
(10cm * 8.2 cm)
Compression Ratio: 8.3:1
Displacement is pi * r * r * stroke or
3.1415926 * 5cm * 5cm * 8.2cm or
644.026 cc
OK, so the ratio of (piston down volume) to (piston up volume) is 644 + head volume : head volume, or 8.3:1
make an eqn:
644 + Hvol = 8.3 x Hvol
7.3 x Hvol = 644, head volume = 88.22cc (sounds big to me)
Do the same for the 600 stock specs to get the 600 head volume, then run the numbers the same way but with the larger bore but with a 'stock' 600 piston, then see how much extra volume the high-comp piston must take up, then apply that info to the 650L numbers (with the larger bore).
maybe I'll have time to crunch those numbers later...
Dave
  • XR650L_Dave
Posted May 29, 2007 - 02:56 PM
XR600R:
97 × 80 mm, 9.0:1
displacement is 591cc, 8x Hvol = 591, head volume is
73.875cc
Take the stock piston and bore it out to 101mm-
new displacement = 641cc
641 + 73.875 : 73.875 = 9.67:1
Now, the higher comp piston brings that CR to 10.6:1
again, 641 + Hv = 10.61Hv, head vol = 66.7cc
73.875 - 66.7 = 7.715, so the high-comp piston takes up 7.715cc of head volume.
Dave
  • XR650L_Dave
Posted May 29, 2007 - 03:04 PM
OK, 650L with the big bore:
101mm x 82 mm gives a 657cc displacement.
657 + 88.22 : 88.22 is 8.45 :1 with the stock piston
sub 7.715 off that head volume and you get a 80.505 effective head volume.
657 + 80.505 : 80.505 = 9.161 : 1
So, 9.161 : 1 should be the comp ratio if you stuff that piston into an XRL. (If I'm not fulla malarky!)
BTW, there's an easier way to do some of that if you look at the % diff in the values, you just have to remember to div. by 2 and square in the right places.
Dave
  • exaresix
Posted May 29, 2007 - 03:38 PM
My 9:1 ratio used similar calculations, not sure why mine came out slighly lower.
  • Billahjack
Posted May 29, 2007 - 05:46 PM
Engine 1: XR600R
bored out to 101mm
stroke is 80mm
Engine 2: XR650L
bored out to 101mm
stroke is 82mm
Hey all, I remember this from college, but had to look it up on the internet to refresh myself since I haven't used it since. I'm getting higher calculated result at 10.9:1. I am thinking that this number is probably a bit high and estimating that the actual compression ratio will be near 10.5:1. See below for the explanation.
Compression Ratio = (Displacement + Static Volume)/Static Volume
Static Volume is the volume left in the cylinder at TDC (piston relief and/or dish, Deck height to Piston volume, Head gasket volume, and combustion chamber volume minus spark plug volume)
Now reworking the formula for the information we have, you get the following:
Static Volume = Displacement / (Compression Ratio - 1)
Now to do some math...
Here are the XR600R calculations:
XR600R 101mm Piston, 80mm Stroke, 10.6:1 Compression
yields <<59.4667cc>> static volume. (I used Excel for the calculations and came up with 640.9477 cc Displacement)
XR600R 97mm Piston, 80mm Stroke, 8.3:1 Compression
yields <<64.6872cc>> static volume (591.1849 cc displacement)
There is a 5.22cc static volume difference.
Here is some guess work...I estimate that the head gaskets are both 1.5mm thick (torqued head) and am using the piston diameter so...
600R stock head gasket =11cc
600R Big Bore gasket = 12cc
This makes a 1cc hit for the big bore
On the 650L, I estimate the Static Volume reduction will be 4.22cc with the high compression piston.
Now for the 650L computations...
XR650L Stock 100mm Piston, 82mm Stroke, 8.3:1 Compression
yields <<70.55cc>> static volume (Using Excel, I came up with 644.026CC Displacement)
Assuming that the static volume is now 66.34cc (from 70.55cc above) when changing to 101mm bore, the calculation for the 650L with 101mm bore, 82mm stroke, 66.34cc static volume is: 10.9:1 using the first compression formula listed above. **Note that the static volume difference is where the calculation uses an assumption that is probably inaccurate.**
This is probably 90% close but not accurate for the following reasons:
-The Cylinder bore is always larger than the Piston (that is why your bike is actually 649cc versus 641)
-The static volume changes when a different head gasket is used (diameter and thickness differences).
-The stock 650L and 600R pistons are not identical and therefore we cannot accurately calculate the static volume difference as I did above.
-If the wrist pin centerline to piston crown distances for the stock XR600R and XR650L are different then this is inaccurate.
Note: I had to edit this after rechecking my work.
  • Billahjack
Posted May 29, 2007 - 06:27 PM
On second thought, you can go here....
XR650L 101mm JE Piston
http://www.xrsonly.c...emart&Itemid=77
XR600R 101mm JE Piston
They are two different part numbers for the XRSonly catalogue. I'm not sure if JE stocks them as two different numbers.
  • sbenja2003
Posted May 29, 2007 - 08:01 PM
The wrist pin centerline to piston crown distances for the Je XR600R and XR650L are different by .060 with the 600r being the smaller of the 2 so if the 650l piston is 10.5-1 then with .060 more room in the cylinder it would have to be in the 9s.
  • machman
Posted May 30, 2007 - 05:35 AM
You guys are unbelievable. I can't thank-you enough. Absolutely my deepest thanks for the answer and the tutorial. Not only do I have an answer, I know how to get my own next time!
9.2:1
  • Billahjack
Posted May 30, 2007 - 05:52 PM
I'm not sure if you noticed, but you can alter the compression ration through changing the head gasket thickness. A difference of 0.5 MM (or 0.020") can probably give you 1 point on the compression.
I've seen "thick" head gasket kits for older high-compression muscle cars that allow you to run current pump gas in them. Of course, they lose power doing this.
I've also seen "thin" JDM gasket kits for Supra Turbo engines that raise compression.
  • XR650L_Dave
Posted May 31, 2007 - 07:43 AM
You can do the same with the base gasket- but how much can you do this without affecting the valve timing?
Moving the cam closer to the crank will retard the valve timing.
Dave
  • Billahjack
Posted May 31, 2007 - 05:10 PM
Moving the head .020" up or down is probably 5 times less effect than your cam chain stretching over time and changning your cam timing. You cam chain probably stretches 1/8" or more.
  • XR650L_Dave
Posted June 01, 2007 - 08:07 AM
Yeah, I didn't mean to infer big changes.
Well, since this is a math thread already-
- assume the crank sprocket has a radius of one inch.
dist. around an arc is the radius x the angle (in radians), write as
S = R x angle, angle = S/R
angle (radians) = 0.020 inches / 1 inch = 0.020 radians
pi radians = 180 deg., so angle (deg) = 180 x 0.020 / pi
angle = 1.14 degrees of valve timing retardation.
Bigger than I thought.
Anyone have an XRL crank out so we can actually measure the radius of the sprocket?
Dave
Washington
  • Hot  32 replies
  • Hot  29 replies
  • 9 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
