XR600 Spark Plug Removal
15 replies to this topic
  • pd10913
Posted May 28, 2007 - 07:26 AM
I might be the odd one out but I've noticed that removing the spark plug from my XR600 is a bit tricky and since I have fitted an Acerbis Long Range Tank, it is now an absolute pain in the ass, so much so I avoid even attempting to remove and check the condition of the plug.
Is there an easier way or a specific plug remover for this task?
At the moment I just use a standard plug socket wrench
  • Jon-D
Posted May 28, 2007 - 07:48 AM
i feel your pain. I have a larger tank as well so I end up pulling it before changing out the plug to make things easer. I use a spark plug wrench (a tall cheap one with the holes at the top) to remove the plug. My automotive spark plug wrench's don’t fit as easily and seem a bit cumbersome in comparison.
  • creeky
Posted May 28, 2007 - 08:15 AM
The plug wrench that comes with the bike's tool kit works best. Don't forget to blow the accumulated dirt and crud away from the spark plug base before removal.
  • Firelyle
Posted May 28, 2007 - 08:32 AM
I don't have an oversized tank but I know it is a complete pain to change a plug without the right wrench for that bike. Not too expensive to get but well worth the money!
  • pd10913
Posted May 28, 2007 - 09:01 AM
Thanks for that, I'll chase up honda for a proper wrench, be worth the cost I reckon!
  • Jeff@TheQuadShop
Posted May 28, 2007 - 05:13 PM
Actually the best plug wrench to use is the one that came with the XR400, it is a hinged design and works very easily even with my Acerbis 5.8 tank.
  • Beerad
Posted May 29, 2007 - 01:24 PM
Like Creeky said, the one that comes with the bike works the best. All the aftermarket ones (Sockets and such) are too thick to fit into the hole. :)
  • focallength
Posted May 29, 2007 - 01:37 PM
I had to use the wrench that came with the toolkit in the saddlebag. Ordering it will run you about $20. All normal 18mm sockets are too thick in diameter and cant fit into the well. the plug remover that comes with the bike works just fine.
  • butcharin
Posted May 29, 2007 - 01:50 PM
I bought a cheap 18mm plug socket and turned it down to fit. The socket was like $4 and I have used a metal lathe. my 2 cents.:)
  • Jeff@TheQuadShop
Posted May 29, 2007 - 04:06 PM
If your going to buy one from Honda, the one for the XR400 works better than the one for the XR600. I have both and always use the one for the 400 because of the hinge and it uses a 14mm wrench instead of a screw driver to turn it. You have more angle options with the wrench than you do with a screw drive and the holes.
  • pd10913
Posted May 30, 2007 - 01:37 AM
excellent, a 400 wrench it will be.
Thanks
  • pd10913
Posted May 30, 2007 - 05:22 AM
Just to confirm, when you say the 400 is better because of the HINGE, I take it that it is not the ordinary long reach socket for the 400 that can be turned with either a spanner or a ratchet?
It's just Ive been looking on the web and most of the 400 plug tools I can find are just that but I'm interested in this hinged one because of the oversize tank I have.
  • Jeff@TheQuadShop
Posted May 30, 2007 - 06:44 AM
The hinged one is the one that came with my 96 XR400 when I bought it new. It is about the same lenght as the one that comes with the XR600.
It can be turned with a 14mm wrench or a ratchet and socket. I have an IMS 4.7 and Acerbis 5.8, it works with both tanks perfectly.
  • Coolidge
Posted May 30, 2007 - 02:12 PM
My 18MM $nap-On socket was thin enough to fit w/out mods to socket
  • 1991xr600
Posted February 07, 2016 - 01:57 PM
yeap coolidge is right, an off brand 18mm long shaft from advanced auto fit with a little socket extender on an 3/8 drive..$5.95
Edited by 1991xr600, February 07, 2016 - 01:58 PM.
  • JoeRC51
Posted February 07, 2016 - 04:06 PM
I've got a plug socket from Autozone. It has a swivel extension attached to the back of the socket.
