Wr400 Rear Shocker!
3 replies to this topic
  • DEANO 23
Posted May 27, 2007 - 08:22 PM
Hi , new guy needs a little help here! The rear end on my 98 wr 400 is all spring ! Its like riding a horse! Any mods or setup tips would be appreciated thanks,
  • Birdy426
Posted May 27, 2007 - 11:23 PM
Is there any oil left in the shock? Try setting the sag properly, then increasingthe damping using the adjustments on the shock.
  • MaxPower
Posted May 28, 2007 - 05:55 AM
[COLOR="Green"]If you fill the rear shock with 90w gear oil it should slow it down a little[/COLOR]
  • DEANO 23
Posted May 28, 2007 - 09:16 PM
Thanks I will check and try your suggestions this thing hasnt seen the light of day since 99 so I have lots of bits "n" pieces to sort , that said 8 years a basic service and fired up 1st...... well maybe 5th kick not bad!
