new rings and valve grinding ?? help guys !!
7 replies to this topic
  • mikey 4410
Posted May 27, 2007 - 10:39 AM
my xr600 is very easy to kick over when trying to find tdc and i keep MISSING it. its done 30,000 kms. please any advice would be great
thanks in advance
  • kellismechanic
Posted May 27, 2007 - 11:52 AM
Check the compression, wet and dry, if it is under 100psi, you need rings, if the wet reading is higher, if it is the same, you need the head worked on, as in valves.:) :ride:
  • Billahjack
Posted May 29, 2007 - 06:56 PM
What is wet versus dry compression? I always just screwed the tube into the sparplug hole and kicked it over.
  • creeky
Posted May 29, 2007 - 07:04 PM
Do the compression check in the normal manner, then pull the spark plug and squirt a generous amount of motor oil into the spark plug hole and repeat the compression check. If the compression improves significantly after squirting in the oil, the rings are worn. If the compression does not improve, the valves are the culprits.
  • Billahjack
Posted May 30, 2007 - 05:54 PM
Cool! Thanks for the tip. :thumbsup:
  • NavyNuke
Posted May 31, 2007 - 03:59 PM
thanks for the tip. never heard that.
  • butcharin
Posted June 01, 2007 - 05:37 AM
Does the auto decompresion affect the compretion check?
  • XR650L_Dave
Posted June 01, 2007 - 07:55 AM
XR650L auto-decomp does drastically lower the reading.
You are supposed to see, 90 psi I think with it active, and much higher when you disable it by loosening one of the exhaust tappets a bit.
Dave
  • Hot  60 replies
  • 17 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 22 replies
  • 9 replies
