More XR600 jetting questions!
8 replies to this topic
  • pd10913
Posted May 26, 2007 - 09:53 AM
98' XR600 - Have just installed an FMF Powercore 4 pipe, removed snorkel and ground header welds and as the beast still had stock jetting I started with a 155/68 setup and the bike was wicked, heaps of power but didn't respond quickly when I let off the throttle, also as it ran best with the fuel screw all the way in (I only ran it like this for about 5 mins) I figured it was too lean.
I then tried the same mj with a 65 pilot and it didn't run nearly as good and coughed and farted a fair bit more. I carried out both the adjustments correctly I believe so my question is, should I try the 68pj again with a 158mj or somethin similar. Jetting is not my specialty and I just want to get it right.
Any suggestions PLEASE??
  • creeky
Posted May 26, 2007 - 01:54 PM
My XR600s ran best with a 160-162 main and a 62-65 pilot. Elevation here is 500-800 ft.
  • FZ1426
Posted May 26, 2007 - 07:52 PM
I think '98's come with a restricted intake manifold. No?
  • cleonard
Posted May 26, 2007 - 10:16 PM
You will need at least a 158, if not the 160/162 that Creeky recommended. I don't have an aggressive exhaust and I run 158/68 at lower altitudes.
  • rmhrc630
Posted May 26, 2007 - 10:35 PM
You cant jet the lack of response out unfort. The stock XR600 carb is a pos.
Fit an FCRMX for respondo power
  • pd10913
Posted May 27, 2007 - 01:30 AM
Thanks for the advice, I'll pick up a 158 & 160 and see how we go from there.
  • Kawabuggy
Posted May 27, 2007 - 03:10 PM
See my signature for specs-Currently running 158 main, and 68S pilot with full Big Gun Evo exhaust. The bike runs very well. The only thing I have yet to try is stepping up to a 160 MJ. Currently the 158 is fine, but until I try the 160, I don't know if it is the BEST or not.
  • pd10913
Posted May 28, 2007 - 01:57 AM
Kawabuggy also which clip position are you running on the needle?
  • Kawabuggy
Posted May 28, 2007 - 03:19 PM
The 3rd I believe. Whatever it is stock, that is the setting it is still at. I have not tried changing the clip position yet but might be willing to give it a shot if there is additional power hiding there.
  • Hot  29 replies
  • Hot  60 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 4 replies
  • Hot  35 replies
