Completely Destroyed my YZ450 motor - what to do now?
24 replies to this topic
  • Pozi
Posted June 06, 2007 - 06:51 AM
#21
I grenaded my engine while at the dunes. It floated a valve and impaled it into the piston. I looked on ebay for a new engine but decided to have mine repaired to avoid the risk of inheriting someone else's problematic engine. Get yourself a OEM TT membership and get the parts from them. They are the cheapest by far. Good luck.
  • NateW
Posted June 06, 2007 - 08:29 AM
#22
The problem with the damage my motor took was the fact that the crank completely bent then mashed up the engine case. If it was just piston/cylinder/head I would probably consider fixing it. I went out and bought a '03 YZ250 yesterday so the 450 is going to get parted out. I do appreciate all the suggestions/advice about this.
Are the 250 / 450 wheels compatible? I might keep them if that's the case. Any other bits and pieces worth keeping from the 450?
  • mn519
Posted June 06, 2007 - 09:00 AM
#23
Yes your wheels should interchange both front and rear. You may need new spacers, but i doubt even that being they are the same year. Also your forks and shocks should interchange(but valving and spring rates would be different). I think the footpegs will also, probally the swingarm too. You can keep that stuff if you think you need it, but the forks/shocks/swingarm are the most valuable to sell on ebay.
  • YzGuy79
Posted June 06, 2007 - 09:13 AM
#24
Wow you need to keep that piston. :thumbsup: That's an awesome trophy. Amazingly you are the 3rd person I've seen do that exact same thing. Float a valve and blow it right through the piston.
Cheers:ride:
Perhaps there's something wrong with Yamaha's valves / engines........cough cough cough:busted: :) :ride: :ride:
  • Pozi
Posted June 06, 2007 - 09:19 AM
#25
Cheers:ride:
The piston is proudly displayed on my workplace desk!
