oil change
6 replies to this topic
  • 426_kid
Posted May 25, 2007 - 06:17 AM
So im doing my 8 hr oil change and this is the first ive done on this bike, I found the oil drain plug but i cant find where you fill it back up at.:) so if someone could help that would be nice thanks:ride:
  • Ranger18
Posted May 25, 2007 - 07:15 AM
If your on a 426, you can fill it up through the dip stick hole on top of your frame, behind your headset (triple clamp assy.)
Posted May 25, 2007 - 08:27 AM
Two questions:
You did drain the frame AND the crankcase, right?
You do have a manual, right?
http://www.yamahaown...ook.com.au/?r=0
  • Maximus83
IS that really the ONLY way on the 426?
Posted May 25, 2007 - 08:55 AM
What are you asking? The older (Pre '03) method is actually better than the newer one, because the oil is actually added to the reservoir where it is stored while running. It certainly simplifies adjusting the oil level after the initial run up.
  • 642MX
Posted May 25, 2007 - 06:34 PM
Its not bad pouring the oil into the dipstick hole, unless I happen to have my 3.9 gallon tank on. Then it takes a foot long funnel and a little luck. :)
Posted May 25, 2007 - 07:49 PM
He may be thinking in terms of the dipstick hole on a 450, which is only 10mm. The dip stick hole in a 426 is designed as the filler port, and the threads are more like 19mm.
  • 10 replies
  • Hot  113 replies
  • Hot  47 replies
  • On January 15, 2017
