chain question????
5 replies to this topic
  • madfish
Posted May 24, 2007 - 04:57 PM
will i need a spacer if i run the did x-ring on 07 yz 450. if so how do i install spacer??
Posted May 24, 2007 - 07:58 PM
Not necessary.
  • Polar_Bus
Posted May 25, 2007 - 09:51 AM
keep a close eye on the M/L "U" clip, the wider O/X chains tend to allow the rear chain buffer to wear the clip down to the point where the clip can get so thin it pops off the link, and you've got a thrown chain, possibly a snapped case...
  • jrny426
Posted May 25, 2007 - 10:02 AM
I noticed the ML clip on my 426 has some wear ..this is normal with O ring chains?
Posted May 25, 2007 - 10:12 AM
It's pretty normal with any chain, really. On Regina chains, as an example, The premium RX3 non-sealed chain uses 18.1 mm pins, while their ORN6 O-ring chain uses 20.4 mm pins. That makes the chain all of .092" wider, and only .046" per side.
But just because they all do it doesn't mean it can't eventually cause a problem.
  • Ga426owner
Posted May 25, 2007 - 01:19 PM
keep your eyes on every M/L U Clip, on all chains. This wears relatively fast and I change them out several times per chain lifespan....I have tried it the wrong way and these will break after a while sending you on your head with a thrown chain.....and possible broken cases. When they get very sharp on the outer edges swap them for new....:)
