0w-40
4 replies to this topic
  • 07XR650L
Posted May 22, 2007 - 04:57 PM
I'm in a pinch here guys. I need oil tonight so I can get to work in the morning. I'm searching my local area for oil and nobody carries what I need. The only thing I can find is 0W-40 synthetic at Wal-Mart. I don't want to start an oil debate over synthetic vs. conventional... I just want to know if 0W-40 is OK to use. I've never even heard of 0W-40, will it work? And secondly, should I use it? Thanks in advance,
  • bigredxr
Posted May 22, 2007 - 05:12 PM
should be great @ start up and a 40 weight when hot. Don't see a down side to using it. Mobil 1 0w40 is the only oil that can be used the chrysler crossfire 3.2 liter v6 engines which is actually a Mercedes engine and they go 500,000 miles no problem. I know not apples to apples, but info to think about. Use it until u can get your hands on a motorcycle synthetic. :)
  • 07XR650L
Posted May 22, 2007 - 05:16 PM
According to the guy I spoke with on the phone at Wal-Mart it was
Mobil 1 0W-40 motorcycle oil.
I think it sounds alright too, but I am hesitant to use something other than what the manual calls for.
  • Owyhee
Posted May 22, 2007 - 05:46 PM
I use the 0-40 Mobil 1 (car stuff) in my 600 in the winter (below freezing). It may be my imagination but I find it easier to kick when the temp is in the teens.
I don't run it when it's warm out, but I go about 400 or 500 miles in the winter between oil changes with no burning, clutch slippage, etc.
"O"
  • cleonard
Posted May 22, 2007 - 06:30 PM
You will be fine with that oil. The 40 is the important number. In the aircooled 650L you want a 40 or 50 oil. The 0W means it is thin at low temperatures and the lower the better. 0W-40 is better than 10W-40 in this respect.
I run the Rotella 15W-40 stuff and it works great. I run it in all my bikes, cars, and trucks. Lower cost and I only buy one kind of oil.
  • 17 replies
  • 3 replies
  • 9 replies
Honda XR650L 2016
  • 0 reviews
