Bearings (sealed)
7 replies to this topic
  • #1_Hit-man
Posted February 09, 2002 - 09:04 PM
Anyone know where to get the best sealed wheel bearings at? THANX! in advance ~Hitman~
  • lewichris
Posted February 09, 2002 - 10:21 PM
http://www.rockymoun...sp?sid=00649190
rocky mountian ATV. 4.50 a bearing you need three and one seal. they have all of it. best seald bearing price i have found. Good luck
  • WR_Dave
Posted February 10, 2002 - 01:58 AM
Whenever I put in new bearings anywhere on the bike I always "carefully" pry the seals off of both sides of the bearing and fill them with a good synthetic grease. Then push the seals back into the bearing. (Use a fine pick to pry up the seals) Bearings usually have a shocking lack of factory grease.
  • AZWR426
Posted February 10, 2002 - 07:30 PM
Be carefull about adding new grease. Too much grease and you get a process known as "churning" in the lube and it starts to break down the grease. Mark
  • #1_Hit-man
Posted February 11, 2002 - 08:02 AM
Has anyone tried Pivot Works bearings? Looks like $55 for both front and rear Wheel bearings and seals. Does'nt sound to bad, anyone try them? Any feedback would be helpful, THANX! :) ~Hitman~
[ February 11, 2002: Message edited by: #1 Hit-man ]
  • SFO
Posted February 13, 2002 - 06:07 AM
I just got sealed SKF brgs for my front wheel and they were 40$ each. The brg house thought they were for a bicycle, being an odd-ball size and all. I would not use chinese brgs after replacing all the stock ktm brgs in my ktm with skf after they barfed after 6mos...
  • lewichris
Posted February 13, 2002 - 06:44 AM
why in the world would you spend 120 bucks on bearings. when you could spend less. Unless you have money to burn.
  • sabin
Posted September 15, 2002 - 02:41 AM
Men,
I got scared looking in those prices.
Over here one european made SKF sealed bearing is $7. I guess you goverment put good taxes on european goods...
