Electrical Question
7 replies to this topic
  • pman13
Posted May 21, 2007 - 08:27 AM
There isn't a general maintenance/tech forum so I'll just throw a question here. What kind of electrical connector do you use when you need to connect three wires? I'm trying to finish some wiring for my new headlight and taillight and I haven't found anything that really looks robust enough for off-road use.
Thanks.
  • martinfan30
Posted May 21, 2007 - 09:12 AM
the best thing to do is solder and shrink tube. this way it wont loose conection or get high in resistance over time due to offroading.
  • pman13
Posted May 22, 2007 - 05:08 AM
I'm not a big fan of soldering wires together because then you can't take it a part when you need to repair/replace something. Any other ideas?
  • martinfan30
Posted May 22, 2007 - 06:37 AM
wirenut!!:) :ride: :bonk:
  • suharianu
Posted May 22, 2007 - 06:55 AM
I would use weather proof connector like this on ebay:
  • martinfan30
Posted May 22, 2007 - 08:11 AM
that is sweet! did you search connectors?
  • Firelyle
Posted May 22, 2007 - 12:50 PM
I'm with Martinfan. If you solder it correctly it is only a small spot that can easily be cut out and replaced if need be. Any type of connector (even weather resistant) is prone to failure. I wouldn't want to be caught out in the middle of nowhere when that "what if" happens...
Just a humble opinion!
  • kellismechanic
Posted May 26, 2007 - 03:52 PM
Me Too:thumbsup: I replaced all the connections on my Baja Designs kit to solder and shrink tube, it's not hard to clip a wire and solder it back, and it will never come loose or corode
