YZ400F Hotstart System
17 replies to this topic
  • Qwik Gixxer
Posted May 21, 2007 - 07:47 AM
HELP!!!!!!! Just bought a 98YZ400F. Someone has disconnected the Hotstart setup. There is a place on the frame where it is supposed to be but its been removed and the line going into the intake manifold is plugged (With a Golf TEE!) My right foot may never be the same. The price was 1G below bluebook so I am not dissapointed. The bike makes Great power and pulls like crazy (Jetting is a little off though) Is the Hotstart neccessary ? Or is it just make it a little easier to start?
  • teddy81
Posted May 21, 2007 - 07:49 AM
i have a kx450 and the hot start broke off during a race and I called Kawasaki they said it wasnt necessary just make sure its closed, I am sure yours is the same way.
  • John221ex
Posted May 21, 2007 - 07:52 AM
You are going to miss that when it's stalled and hot. It really helps to get going again.
John
  • Qwik Gixxer
Posted May 21, 2007 - 08:05 AM
Thanks John. Thats what I figured. I guess I will have to spend some money
  • jayh300
Posted May 21, 2007 - 08:34 AM
i have a 99 400 and had never used the hot start. one day I needed it and mine was stuck shut. the plunger would not pull. I did the zip ty racing remote hot start that mounts on the handle bars. much easier to use imo.
  • Qwik Gixxer
Posted May 21, 2007 - 08:36 AM
Where did you get it.Price?
  • Qwik Gixxer
Posted May 21, 2007 - 09:05 AM
Called ZipTy and they are seeing if they have the pieces neccessary for the kit.
  • jayh300
Posted May 21, 2007 - 09:18 AM
it was on the zip ty website. i think they listed it for the 400 specifically. It came with everything needed. even the plug for the air box.
  • Qwik Gixxer
Posted May 21, 2007 - 09:20 AM
No longer a stocked item (not enough demand. he is seeing if he has the parts to do a kit.
  • jayh300
Posted May 21, 2007 - 09:33 AM
that is too wierd. on the website it shows they have them in stock.
part number HSS0001 and shows to fit all yzf's and some ktms. search by products, then spec bike and it comes right up.
I just got this same setup less than a month ago.
good luck
jay
  • 2wheels-drz
Posted May 22, 2007 - 07:10 AM
WOW, I think you where feed alittle BS there....like sure the bike will start, but it deffo will take a few kicks more. i would have liked to see that guy tell bubba, "you don't need a hot start, just kick it over a few times more" i'm surprised at kawi giving you an answer like that:eek:
Posted May 22, 2007 - 08:33 AM
He may have been trying to say that you can keep using the bike until you get it fixed, not that it was totally unnecessary.
  • Qwik Gixxer
Posted May 22, 2007 - 03:24 PM
My YZ will start when its hot but its anything but easy.
  • AlkalineOne
Posted May 22, 2007 - 05:42 PM
i had a 98 yz400f and man that thing ran hot! but i never needed the hot start. the thing would often overheat, steam everywhere..., and it would still kick over on the first strong kick.
however, i would get rid of the golf tee...
  • Qwik Gixxer
Posted May 23, 2007 - 02:46 PM
I did. Capped the outlet on the manifold. its not gonna help the starting problem but it does look a lot better.
  • wi_zee_ef
Posted May 25, 2007 - 09:01 PM
Hey Qwik, I have a DrD bar mounted hot start. It's useful if you are climbing a hill & stall, then want to kick it over without falling off the slope trying!
I have the old stock parts if you want. Send me PM if you are interested.
  • Qwik Gixxer
Posted May 26, 2007 - 03:03 PM
Check Your PMs
  • felix 222
Posted May 26, 2007 - 06:51 PM
i use it for starting about 10% of the time. it does come in handy after having stalled.
