Speedo Cable / YZ Timing
2 replies to this topic
  • Guest_Guest_*
Posted January 22, 2001 - 07:10 AM
Got the YZ front plate....Now what do I do with the Speedo cable/Wheel spacer
Does anyone know for sure about YZ Timing, Does the 01 need the change or did it come stock.
Has anyone purchased the BajaDesigns Cam/Jet Kit(in catalog) is it worth it....Thanks
  • Buck
Posted January 22, 2001 - 07:51 AM
The odo must be taken off. I use an old odo drive as the wheel spacer to beep the bearings covered. As far as your question about timing. I don't know. I have 1999 machines.
  • Ron_in_SoCal
Posted January 22, 2001 - 08:37 AM
You need some more YZ parts to fix the wheel spacer problem right.
'00 Part Numbers / Descriptions
93102-26468-00 OIL SEAL
5BE-25186-00-00 COLLAR, WHEEL
5DH-2314J-00-00 PROTECTER COMP.
