Has anybody ever put an XR650R engine in a smaller modern bike?
9 replies to this topic
  • 4Takt
Posted May 17, 2007 - 04:27 PM
You know the CR500AF thing where they shoehorn CR500 engines into modern 125s. Has anybody ever done anything similar with an XR650R engine?
Just wondering what that would be like, that engine in a 220lbs bike that you could flick around in tight stuff.
  • jbird710
Posted May 17, 2007 - 05:05 PM
I've never seen it; but I wonder just how hard it would be to put one in a CRF450 frame? Might have to break out the tape measure.:)
  • Supplicate
Posted May 18, 2007 - 08:25 AM
http://www.thumperta...ighlight=CRF650
  • 4Takt
Posted May 18, 2007 - 12:19 PM
No, not at all what I had in mind.
  • jbird710
Posted May 18, 2007 - 12:27 PM
That bike looks extremely impressive but it doesn't actually use a CRF frame. It also looks like it would be extremely hard to stuff the XR650R engine in the cradle of a CRF frame. There wouldn't be any room to do maintenance on the top end without dropping the engine.
  • augustiron
Posted May 19, 2007 - 12:52 PM
I've seen a beautiful Aprilia RS125 with an XR engine swap in it, they race the singles class. I'll look for it
  • xrfred
Posted May 19, 2007 - 01:17 PM
xr motor weighs alot more than 450 there is not much to be gained unless you want to pump it up like over 60rwhp (except linear powerband)
  • 4Takt
Posted May 19, 2007 - 07:07 PM
I'd love to see that.
  • DiabloCaballo
Posted May 19, 2007 - 09:03 PM
If your gonna go through that much trouble and expense why not put a CBR600RR motor in there, that would be cool :)
  • Shawn_Mc
Posted May 20, 2007 - 04:53 PM
Ive seen stock bore and stroke 450's make over 60 with an almost flat torque curve.
Something like that would wear you out worse than a 650 because of the way it'll accelorate. Its a simple power to wieght ratio deal. And if you put a heavy enough flywheel on it, you may as well just ride the 650 in the first place. :)
