XR200R Flywheel removal
17 replies to this topic
  • red021200
Posted May 16, 2007 - 12:18 PM
What size bolt/puller does it take to pull the flywheel off an XR200R?
  • Torqd
Posted May 16, 2007 - 01:05 PM
use your rear axle and an impact... good luck!
  • andy_t
Posted May 16, 2007 - 01:10 PM
What? There is a tool to do this..... I wouldn't recommend anything else. I tried and tried to get my XR100 FW off using a gear puller after taking the nut off. Just about screwed the FW up.... Went to the local MC shop and for $25.00 bought the FW puller tool. It took more time to take it out of the package then it took to get the FW off using it.
andy t.
  • hondamotodad
Posted May 16, 2007 - 06:25 PM
I believe it's 16mm x 1.5 pitch. I got mine on EBay for around $10. I used a strap to hold the flywheel while tightening the puller and then whacking it with a hammer. Took about 5 repetitions to get it off.
  • Salsa
Posted May 16, 2007 - 06:33 PM
Go to a bolt supply place. I got 2 for $5-6. Just be sure you know what size bolt you need.
Don
  • Torqd
Posted May 17, 2007 - 09:39 AM
Sorry.. I thought I was on the 150/230 thread. I am pretty sure it is the same on the 200 though(it has been a while since I have worked on a 200 bottom end).
The rear axle on the bike is the same size and pitch as the flywheel puller and it is free to use... I have had my flywheel off over 20 times on several 150/230 and 200 bikes. It just threads into the flywheel and presses it off the crank taper.
You can act as if I am dumb if you want... but I know what works...
To each their own.
Good Luck.
  • sil
Posted May 17, 2007 - 10:37 AM
lol, i gotta try that
  • red021200
Posted May 17, 2007 - 11:13 AM
Thanks, guys I will use the rear axle.
  • CRM114
Posted May 18, 2007 - 06:22 AM
Ha!
I was going to ask this same question. I pulled the stator off my project motor last night and instantly knew I'd need something for the flywheel. And it just so happens I've got a spare axle! ThumperTalk read my mind! :)
Still looking for a right side/clutch cover for a '96 XR200. I guess I could find somebody who welds aluminum and see if they could fix it?
John
  • fordfreak300
Posted May 18, 2007 - 08:13 AM
I swear i just saw a complete 2000 XR200 being parted on e-bay the other day. Take a look.
  • CRM114
Posted May 18, 2007 - 10:05 AM
The cover wasn't available. He was selling it with the bottom end, less the stator. I thought that was kind of wierd. Anyway, it went for $202. Besides, I tried to get some information and the seller was evasive so I bowed out.
John
  • XR-rated
Posted May 19, 2007 - 04:49 PM
Just take the rear axle and screw it into the hole. Take a Cresent wrench and open it up enough to slip over the shaft of the bolt but catch the head. Hammer it out.
  • CRM114
Posted May 21, 2007 - 05:41 PM
I fished out my extra axle bolt and discovered it had that steel tab welded to the end of it to keep it from turning. Sort of hard to get an impact wrench on that! Maybe I'll cut it off and file it down to fit?
JB
  • Jeremiah James
Posted April 01, 2011 - 10:13 AM
All I have to say is I bought a FW puller for my girls xr200 and it didn't fit. I ended up using the rear axle, a strap to hold the FW and a couple love taps with a mallet. Had it in my hands in minutes!
  • spiceman
Posted March 28, 2012 - 08:36 PM
I just used rear axle worked. wasnt that easy to tap out though
  • Chuck.
Posted March 28, 2012 - 09:00 PM
As others have said use the rear axle. It screws into the rotor and presses against the crank end. Some axles have a hex head and most have a round head with a tang. Put a vise grip or wrench on the end and strike the wrench a few times with a hammer and the rotor will pop lose from the crank taper.
  • inais
Posted March 29, 2015 - 12:55 AM
sorry to bump an old post.
I am using my read axel, but cant get it out.
I have screwed the axel in to the point where my body weight is hanging off the wrench and still nothing.
  • KTM520EXC
Posted March 29, 2015 - 09:31 AM
Try a rubber hammer, should pop off.
Don't get carried away, just a nice swift blow on the end of the axle.
Michael
Edited by KTM520EXC, March 29, 2015 - 09:50 AM.
xl100s vs xr100 trans difference? by CarmanCRF
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
Top Speed of an XR200 by Yamiha
  • Hot  49 replies
XR100 Bog and Backfire by qwika
  • 3 replies
2003 honda xr100 key switch by Alangray33
  • 8 replies
  • Hot  36 replies
