cable luber tool
5 replies to this topic
  • CaptainKnobby
Posted May 16, 2007 - 06:38 AM
I have one of those tools where you put that clamp on the cable you are lubeing and screw it down then take the stem put it in the can and the other end of the stem in the hole in the clamp and then spray it in. My question is no matter how tite you tighten the clamp the spray still leaks out the end of the clamp. How can you stop it from leaking to get more lube down the cable tubeing?
  • xcape
Posted May 16, 2007 - 11:01 AM
I havent found one that works well myself??
  • Sundog
Posted May 16, 2007 - 11:04 AM
I use a pair of needle vice grip to add additional pressure but ALWAYS have to wrap paper towels around it for the dripping and squirting. Is a pain in the butt.:)
  • LVThumper
Posted May 16, 2007 - 12:40 PM
I'm glad that I'm not the only one who could never get those things to work quite right!! :ride: What a pain in the :) !!!!
  • Markopolo400
Posted May 16, 2007 - 02:34 PM
but ALWAYS have to wrap paper towels around it for the dripping and squirting. Is a pain in the butt.:ride:
Same here.
Even since new, mine has never sealed perfectly. :)
  • CaptainKnobby
Posted May 16, 2007 - 03:00 PM
I've used this method all so and it didnt work.I even took a knife and tapered the straw or stem, if you will.... at the end so it would be more pointed so it would go futher in the hole on the clamp and it still leaked out around the cable housing:banghead: .
  • Hot  28 replies
  • Hot  47 replies
  • Hot  36 replies
  • Hot  50 replies
