Brake Cleaner safe to Clean Carb?
8 replies to this topic
  • Davies
Posted May 15, 2007 - 05:38 PM
I have a gummed up carb with old gas and goo from my 01 wr250f and have it on the table but am not located in an area that sells carb cleaner. can i use brake cleaner? any other good chemicals methods other than buying carb cleaner? I will use a compressor too. Thanks
  • jeremyhensel
Posted May 15, 2007 - 05:40 PM
contact cleaner (electrical contact, not eye contact) is sold at auto parts stores and it doesn't leave a residue like brake cleaner. That said, with the internet I think you could get some carb cleaner in a couple of days.
  • Davies
Posted May 15, 2007 - 06:36 PM
do you think brake cleaner (says leaves no reisdue) will work? I have a spray bottle of it. it does say may harm rubber o rings... hmmm.. is this a sketchy idea or can i do it?
  • 642MX
Posted May 15, 2007 - 06:45 PM
Brake cleaner and carb cleaner both eat o-rings. Most cleaners do.
If you can't find any carb cleaner, brake cleaner will work to clean your carb, but starting fluid works better.
  • jeremyhensel
Posted May 15, 2007 - 06:48 PM
Brake cleaner and contact cleaner both say to keep away from rubber. I would order the carb cleaner
  • Racer24
Posted May 15, 2007 - 06:59 PM
i have Maxima Contact Brake Cleaner and its removes oil, grease, carbon deposits, cleans Brakes, Ignitions, and Carbs...its safe for any rubber o rings....and it has a nice citrus scent :)
its also non-corrosive and non-staining...on the back its says its safe to use on Engine parts, carbs, brake parts, ignition parts, spark pluygs, lockes, electrical components, and more
  • ttr125l95
Posted May 15, 2007 - 08:47 PM
Take the rubber out of the carb before you clean it, buy a bucket of carb cleaner (like one the paint can thingies) take it apart and let it sit in the can for like 2 hours then come put it back together again. With brake cleaner or carb cleaner you will need to avoid contact with the rubber components.
  • Slapnut
Posted May 16, 2007 - 04:43 AM
Isn't BRAKE cleaner for...er...um...well BRAKES!
Leave it for a week or two in some kero or mineral turps and all will be sweet.
  • thumpinyami59
Posted May 18, 2007 - 06:40 AM
Brake clean cleans better than carb cleaner. It removes all residue, hence people use it on brakes. I do think it is harder on seals, o-rings, etc. though!
